1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to get a list of all available PVs
To: [email protected]
Date: Mon, 17 Dec 2012 12:29:41 -0500
On 12/17/2012 6:14 AM, Carlos Pascual wrote:
Ronaldo,
Thanks for the tip.
I looked at channel finder docs and I gather that somehow one needs to manually
add the info to the directory itself. I mean, that the channel finder cannot by
itself discover available PVs.
If possible I would like to avoid such requirement of manually creating the
database.
At NSLS2 the process to automatically keep channelfinder up to date is this:
Each IOC init script ends with
dbl > records.dbl
system "cp records.dbl /cf-update/$HOSTNAME.$IOCNAME.dbl"
The two variables are set from the environment by a shell wrapper script for Linux systems, and manually for RTEMS systems.
The location /cf-update is exported from an NFS server and mounted by all IOC host systems. The NFS server has a process which monitors for new/updated files in this directory.
http://channelfinder.hg.sourceforge.net/hgweb/channelfinder/python.channelfinder.api/file/f0d7b9404db3/cf_monitor.sh
When a record list is updated the cf-update-ioc script is run which handles sending the new information to the channelfinder service.
Once the NFS server has been setup this works fairly well. The ongoing problem is to ensure that all IOCs create a record listing file. Also, by design the cf-update-ioc script only adds records, so it a maintenance task to periodically purge orphaned entries.
Michael
Re: How to get a list of all available PVs Rod Nussbaumer
How to get a list of all available PVs Carlos Pascual
Re: How to get a list of all available PVs Pavel Maslov
RE: How to get a list of all available PVs ronaldo.mercado
Re: How to get a list of all available PVs Carlos Pascual
Prev: Re: How to get a list of all available PVs Alan Biocca
Next: Re: How to get a list of all available PVs Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: How to get a list of all available PVs Dirk Zimoch
Next: Re: How to get a list of all available PVs Rod Nussbaumer
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
