Ronaldo,
Thanks for the tip.
I looked at channel finder docs and I gather that somehow one needs to manually
add the info to the directory itself. I mean, that the channel finder cannot by
itself discover available PVs.
If possible I would like to avoid such requirement of manually creating the
database.
By looking at the CA docs, I see that the IOCs emit periodic beacons, so by
listening for at least EPICS_CA_BEACON_PERIOD seconds I should be able to
gather a list of active IOCs. Is that right?
And if so, is there a way of interrogating a given IOC for its PVs?
Cheers,
Carlos
On Mon 17 December 2012 10:27:38 [email protected] wrote:
> Hi Carlos,
> Adding to Pavel's all good suggestions, there is no "native" directory in
> base epics that lists the PVs available on a network.
> Ralph Lange's channel finder is an alternative that some sites may be
> using.
> http://sourceforge.net/projects/channelfinder/
> Ronaldo
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Pavel Maslov Sent: 17 December 2012 08:50
> To: Carlos Pascual
> Cc: EPICS Tech Talk
> Subject: Re: How to get a list of all available PVs
> Hi Carlos,
> on the IOC side issue dbl (in the epics shell):
> epics> dbl
> And you'll get all the PVs loaded in to EPICS database.
> If you want to get a list of PVs on the client side though, then I don't
> think that can be implemented as easily as I have descibed above. You can
> always ssh to the IOC box and either execute st.cmd and use the dbl
> command, or use procServ to connect to a running IOC. In this case, I
> suspect the st.cmd file should contain dbl after the iocInit command. As
> for the latter, I have never used procServ myself. So just guessing.
> On Mon, Dec 17, 2012 at 12:38 PM, Carlos Pascual
> <[email protected]<mailto:[email protected]>> wrote: Hi,
> Sorry for this newbie question... I come from the Tango community, and I am
> quite lost with Epics
> I am a developer of Taurus [1], a GUI library initially designed to provide
> PyQT GUIs on top of Tango. But our goal is to also support other
> communication/control systems such as Epics.
> I recently implemented some very basic support for epics in Taurus (just a
> proof of concept) using PyEpics, and one of the first questions that I came
> across is:
> How can I obtain a list of all PVs that are available?
> ... or even better, can I get a list of all PVs whose name contains a
> certain prefix?
> The reason I want this is that I want to create a browser/selector of PVs.
> I do not care that much if the method is slow (I could live with doing it
> once and only manually refreshing the list).
> But I need the method to be generic, i.e. it should not assume some non-
> standard service (such a site-dependent database) to be available.
> Is this possible at all?
> Cheers,
> [1] http://www.tango-controls.org/static/taurus/latest/doc/html/
> Carlos Pascual Izarra
> Scientific Software Coordinator
> Computing Division
> Cells / Alba Synchrotron [http:/www.cells.es<http://www.cells.es>]
> Carretera BP 1413 de Cerdanyola-Sant Cugat, Km. 3.3
> E-08290 Cerdanyola del Valles (Barcelona), Spain
> E-mail: [email protected]<mailto:[email protected]>
> Phone: +34 93 592 4428
> Best regards,
> Pavel Maslov, MS
> Controls Engineer at Pulsed power Lab
> Efremov Institute for Electro-Physical Apparatus
> St. Petersburg, Russia
> Mobile: +7 (951) 672 22 19
> Landline: +7 (812) 461 01 01
Computing Division
Cells / Alba Synchrotron [http:/www.cells.es]
- RE: How to get a list of all available PVs michael.abbott
- Re: How to get a list of all available PVs Michael Davidsaver
- How to get a list of all available PVs Carlos Pascual
- Re: How to get a list of all available PVs Pavel Maslov
- RE: How to get a list of all available PVs ronaldo.mercado
<2012>
<2012>
