1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem with medmfonts.ali running under Ubuntu 1204
To: [email protected]
Cc: Ivan Kohler <[email protected]>
Date: Wed, 5 Sep 2012 11:11:01 -0500
Hi Ivan,
On 2012-09-05 Ivan Kohler wrote:
> I seem to be having a fonts problem running medm under Ubuntu 1204
> I did the usual cat of medmfonts.ali >>
> /usr/share/fonts/X11/misc/fonts.alias the found that all fonts
> larger than 22 points were missing when I ran medm.  Any thoughts?
That means Ubuntu 12.04 must have removed those fonts from their default
distribution.
> Could this be an open source license issue for these fonts?
I very much doubt it, since they have been used and distributed for years with
no problems, and I other distros do still include them.
Ubuntu probably has the fonts still available somewhere, you just have to find
what package they're in and install it.  If you find the answer please let us
know. On RHEL 6.2 the Sony fonts are in xorg-x11-fonts-misc-7.2-9.1.el6.noarch
and the Adobe fonts are in xorg-x11-fonts-ISO8859-1-100dpi-7.2-9.1.el6.noarch
so I'm guessing they're an optional part of X11 v7.2 which Ubuntu no longer
installs by default.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: Problem with medmfonts.ali running under Ubuntu 1204 Ivan Kohler
Prev: Compilation error EPICS for RTEMS Bruno Seiva Martins
Next: How to get rtems BSP 王林
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Problem with medmfonts.ali running under Ubuntu 1204 Ivan Kohler
Next: Re: Problem with medmfonts.ali running under Ubuntu 1204 Ivan Kohler
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
