In fact, setting EOFF did the trick, now the conversion is happening as expected. Eric, I trusted the top Google result because the URL looks fine and suggests, at least to me, that it's the official documentation for the current version. I will take more care in the future :) I believe it would be more clear if a warning would be put on top of that old page, saying that the most up to date documentation can be found at the wiki.
Dirk, the 'type' variable was already defined in a private structure, so it agrees with your suggestion. I had created a custom function (not specialLinconv()) to setup those conversion parameters. Is there any special reason to use specialLinconv() instead of a custom function? I thought that EPICS would call specialLinconv() every time a conversion was needed (for, say, weird conversion rules), apparently that's not the case.
Bruno Seiva Martins On Tue, Aug 28, 2012 at 12:55 PM, Ralph Lange <[email protected]> wrote:
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
