Hi 李芳,
On 2012-08-08 李芳 wrote:
> My EPICS base is base3.14.8.2, but I want to get access to EPICS
> base3.13.8 in another computer. For eaxmple using "caget" to get a PV from
> base3.13.8 in my base3.14.8.2 system. So how do I should.
Those two versions of channel access are compatible, so they should just
connect. If they don't, that may be because you have a firewall set up in one
or both systems; if that's the case you will need to open up ports 5064 and
5065 for both the UDP and TCP protocols to allow the computers to communicate.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- The communication between base3.14.8.2 and base3.13.8 李芳
Re: Installing MEDM on UBUNTU 10.04 LTS Andrew Johnson
<2012>
Re: The communication between base3.14.8.2 and base3.13.8 Zhang Yuliang
Remaining free buffers in an AD plugin queue Emma Shepherd
<2012>
