1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Installing MEDM on UBUNTU 10.04 LTS
To: [email protected]
Cc: nalaka samarasinghe <[email protected]>
Date: Thu, 9 Aug 2012 10:40:27 -0500
Hi Nalaka,
On 2012-08-09 nalaka samarasinghe wrote:
> nalaka@nalaka-laptop:~/opt/epics/extensions/src/medm$ make
> ../../configure/CONFIG_EXTENSIONS:8: opt/epics/configure/RELEASE: No such
> file or directory
Make can't find the ~/opt/epics/extensions/configure/RELEASE file that it
needs to tell it where Base is installed.  Where did you get the files in your
~/opt/epics/extensions/configure directory?  There should have been a RELEASE
file in it which you will have to edit to tell the build about to your
installation.
> ../../configure/CONFIG_EXTENSIONS:12: opt/epics/base/configure/CONFIG: No
> such file or directory
> Makefile:14: opt/epics/configure/RULES_DIRS: No such file or directory
> make: *** No rule to make target `opt/epics/configure/RULES_DIRS'.  Stop.
> Please help to figure out what is meant by this and please let me know the
> correct way of installing MEDM
The remaining errors should go away once the RELEASE file is present.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Installing MEDM on UBUNTU 10.04 LTS nalaka samarasinghe
Prev: Installing MEDM on UBUNTU 10.04 LTS nalaka samarasinghe
Next: Re: The communication between base3.14.8.2 and base3.13.8 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Installing MEDM on UBUNTU 10.04 LTS Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
