1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Problem in SNL
To: santosh aditya <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 6 Jul 2012 15:56:00 +0000
Did you correctly point to EPICS base in seq/configure/RELEASE?
From: [email protected] [[email protected]] on behalf of santosh aditya [[email protected]]
Sent: Friday, July 06, 2012 10:09 AM
To: [email protected]
Subject: Problem in SNL
I am using Ubuntu V 12.04 32-bit. I have installed EPICS base and extensions. I have started SNL programming. I have installed re2c-0.13.5 and seq-2.1.7.
I am unable to compile the state program. I have attached the program (.st) along with the environment variables.
I have tried to compile using " snc level_check.st -o level_check.c"
But when I compile this C file I am getting following error message
level_check.c:8:24: fatal error: epicsTypes.h: No such file or directory
compilation terminated.
Please help me to proceed further
Problem in SNL santosh aditya
Prev: Re: Problems with parallel make on seq-2-1-7 Andrew Johnson
Next: Re: Problem in SNL Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Problem in SNL santosh aditya
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
