Am Freitag, 6. Juli 2012, 17:09:42 schrieb santosh aditya:
> Hi,
> I am using Ubuntu V 12.04 32-bit. I have installed EPICS base and
> extensions. I have started SNL programming. I have installed re2c-0.13.5
> and seq-2.1.7. I am unable to compile the state program. I have attached
> the program (.st) along with the environment variables.
You did not ;-) Never mind, the problem lies not with your program.
> I have tried to
> compile using " snc level_check.st -o level_check.c" But when I compile
> this C file I am getting following error message
> level_check.c:8:24: fatal error: epicsTypes.h: No such file or directory
> compilation terminated.
> Please help me to proceed further
The EPICS base include directory contains epicsTypes.h and some more header
files that are included by the generated C code. So these directories should be
added to the include path for the compiler command line. I recommend to start
with makeBaseApp.pl as indicated in the documentation (http://www-
csr.bessy.de/control/SoftDist/sequencer/Installation.html#use). You can then
inspect the compiler command line to see which include paths are needed.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Problem in SNL santosh aditya
RE: Problem in SNL Mark Rivers
Re: Re: Problems when download synApps IOC sunjl
<2012>
Re: Problem in seq-2.1.8 Benjamin Franksen
<2012>
