Hi haquin,
On 2012-06-28 haquin wrote:
> I have developped a record which has an ENUM field of 32 elements,
> When I use "caget -d 31 PVname" to retreive the list of elements, I get
> only the 16 first elements.
> Could the "caget -d xx" retreive more the 16 elements ?
No, the problem is that the Channel Access network protocol only supports a
maximum of 16 ENUM states. There is no backwards-compatible way to support
your ENUM field over the network without extending the CA protocol, adding new
data types to the db_access.h file and changing all the CA clients to use
those new types.
Strangely the internal limit for ENUM states within the database code is
higher, it seems to be defined to be 30 there. I have no idea why though, the
alarm status menu has 22 states.
Sorry, but I suspect that your time spent on that record has probably been
wasted.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- caget limitation retreiving ENUM list haquin
RE: caget limitation retreiving ENUM list Hill, Jeff
Re: epicsAtExit Eric Norum
<2012>
Re: caget limitation retreiving ENUM list Dirk Zimoch
<2012>
