haquin wrote:
I have developped a record which has an ENUM field of 32 elements,
When I use "caget -d 31 PVname" to retreive the list of elements, I get
only the 16 first elements.
Could the "caget -d xx" retreive more the 16 elements ?
Regards
Not without breaking the CA protocol.
You can try to change the MAX_ENUM_STATES macro in db_access.h and then
re-compile all EPICS software. But you have to rebuild not only EPICS
base but as well all clients. Client built without the change may not
work with modified IOCs. Tell me if this works :-)
Dirk
- caget limitation retreiving ENUM list haquin
Re: ethernet-based Gamma ion pump controller (mpc) Pavel Masloff
RE: LabVIEW EPICS connection ulrik.pedersen
<2012>
Re: caget limitation retreiving ENUM list Andrew Johnson
ethernet-based Gamma ion pump controller (mpc) Scott Baily
<2012>
