g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Subject: RE: EPICS build on armv6l
To: Florian Feldbauer <florian@ep1.ruhr-uni-bochum.de>, EPICS tech talk <tech-talk@aps.anl.gov>
Date: Tue, 12 Jun 2012 14:40:54 +0000
> would it be possible to build
> EPICS directly on this system instead of building it on a different
> system?
If you are running linux on this system then you should be able to do get a host build of EPICS running with some small additions to the configure/os area of base.
Jeff
> -----Original Message-----
> From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov]
> On Behalf Of Florian Feldbauer
> Sent: Tuesday, June 12, 2012 1:47 AM
> To: EPICS tech talk
> Subject: EPICS build on armv6l
> Dear all,
> we have bought a Raspberry Pi Computer [1] which has an armv6l
> architecture.
> It is planed to use this inside our control system.
> Currently arm is only supported as target not as host for build.
> Since the Raspberry Pi has a gnu c compiler and all
> the libraries I need (also a x-server), would it be possible to build
> system?
> Best regards,
> Florian
> [1] http://www.raspberrypi.org/
> | Florian Feldbauer                 |
> | Ph.D. student                     |
> | Institut für Experimentalphysik I |
> | Ruhr-Universität Bochum           |
> | Universitätsstr. 150              |
> | D-44780 Bochum                    |
> | Office: NB 2/173                  |
> | Phone:  (+49)234 / 32-23538       |
> | Fax:    (+49)234 / 32-14170       |
> | Web:    http://www.ep1.rub.de     |
EPICS build on armv6l Florian Feldbauer
Prev: EPICS build on armv6l Florian Feldbauer
Next: Re: EPICS build on armv6l Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
