1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS build on armv6l
To: [email protected]
Cc: Florian Feldbauer <[email protected]>
Date: Tue, 12 Jun 2012 10:30:43 -0500
Hi Florian,
On 2012-06-12 Florian Feldbauer wrote:
> Currently arm is only supported as target not as host for build.
> Since the Raspberry Pi has a gnu c compiler and all
> the libraries I need (also a x-server), would it be possible to build
> EPICS directly on this system instead of building it on a different system?
Yes, although as Jeff said you might need to add a few things to the
configure/os directory to get it to build.  Since you're self-hosting I think
you should be able to use the generic target name linux-arm for this build,
which should simplify the Base configuration process.
You will need to create the file CONFIG.linux-arm.Common containing the line
    include $(CONFIG)/os/CONFIG.UnixCommon.Common
but that might be all you actually have to do.  CONFIG.Common.linux-arm may
look like it's only set up for cross-compilation, but those settings are
actually overrides to variables set in CONFIG.Common.UnixCommon so first try
building without making any changes there.
In case it's not clear, files names *.<host>.Common are included whenever
building on <host> irrespective of the target; files named *.Common.<target>
are included whenever compiling for <target> on any host; files named
*.<host>.<target> are used whenever that particular combination of <host> and
<target> are involved.  Files named CONFIG.*.* contain default settings for
the build process, while files named CONFIG_SITE.*.* are intended for site-
specific settings such as paths that might vary (location of cross-compilers
etc.).
After a top-level 'make' succeeds, you will want to use 'make runtests' to
execute the build-in test programs (note that epicsMessageQueueTest takes 5
minutes to run, don't assume it has crashed when the messages stop mid-test).
Hope this gets you started, ask if you get stuck.  I would be interested in
adding your configuration files to the Base distribution if you would like to
contribute them once you have everything working.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: EPICS build on armv6l Tim Robinson
EPICS build on armv6l Florian Feldbauer
Prev: RE: EPICS build on armv6l Hill, Jeff
Next: thermocouple solutions Wesley Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: EPICS build on armv6l Tim Robinson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
