I'm not sure I understand this. I am supposing that the areaDetector acquisition can keep up, but that there is a pipeline delay. If the image frames are tagged at the moment they are acquired the TSE should be valid, even though by the time the records process it may not be the same pulse. Wouldn't it be useful to have the TSE be accurate for such PVs even if they don't finish processing until 1 or more events later?
-----Original Message-----
From: Allison, Stephanie [mailto:[email protected]]
Sent: Wednesday, May 30, 2012 11:48 AM
To: Mark Rivers; 'Eric Norum'; Williams Jr., Ernest L.
Cc: EPICS Techtalk
Subject: RE: Proposed change in asyn - request for comments
> Let's assume these are images being collected
> with an areaDetector camera. They may be buffered in the driver and plugins for a few LCLS
> pulses before the waveform record finally processes.
LCLS beam-synchronous-acquisition won't work in this case. It is critical that BSA data be processed before the next triggering event code, even if it means processing data (and giving it to BSA) outside of such "slow" record processing. When processing can't keep up with triggers, we recommend that a "rate-limited" event code be used to trigger the device. Also, we recommend that data going to BSA be processed in records with PRIO=HIGH and any threads processing the data run at a high priority (but of course not higher than the thread processing EVR-related activities).
Stephanie
> From: [email protected] [mailto:[email protected]] On Behalf Of
> Mark Rivers
> Sent: Wednesday, May 30, 2012 9:03 AM
> To: 'Eric Norum'; Williams Jr., Ernest L.
> Cc: EPICS Techtalk
> > I think that you'd be better off setting the waveform record TSE=<the number of
> > some event in your timing system event receiver associated with the pulse>.
> > The waveform record would then get its time stamp from the event receiver.
> I agree that they should set TSE=Event number. But the question is, how to get the correct value
> for TSE into the waveform record in a robust way. Let's assume these are images being collected
> pulses before the waveform record finally processes. If the waveform record then tries to read the
> current event number it will not be correct.
> It seems to me that the low-level camera driver should be collecting the bunch number the instant
> the image is collected, and attaching it to the image. That information should make it back with the
> image in the callback to the waveform device support. So maybe it makes sense to not only have
> a timeStamp passed in the pasynUser, but also a TSE?
> Mark
> From: Eric Norum [mailto:[email protected]]
> Sent: Wednesday, May 30, 2012 10:24 AM
> To: Ernest L. Williams Jr.
> Cc: Mark Rivers; EPICS Techtalk
> Subject: Re: Proposed change in asyn - request for comments
> On May 30, 2012, at 8:07 AM, Ernest L. Williams Jr. wrote:
> > Hi Mark,
> > I apologize for the late response.
> > Here at the LCLS we are indeed interested in this.
> > We rely on our pulseID or "beam flavor" for correlation on a pulse by pulse basis.
> > This will be useful for any piece of data acquisition hardware which has an asyn driver.
> > For example, if I wanted to use your ip330-asyn driver for beam synchronous acquisition (BSA)
> > I hope to encourage more asyn-based drivers here at LCLS but we do need the capability to
> grab the pulseID
> > with the "TSE = -2" technique. :)
> > At this time, there are 2 waveform digitizer VME boards that we have started to work on:
> > (1) Struck SIS3350
> > (2) Struck SIS3302
> > Can we make these asyn drivers and still integrate with GTR? Eric any comments?
> I don't see how GTR and ASYN would go together very easily. Also, I don't think that TSE=-2
> is the right choice for this setup -- the digitizers don't supply the time stamp. I think that you'd be
> better off setting the waveform record TSE=<the number of some event in your timing system
> event receiver associated with the pulse>. The waveform record would then get its time stamp
> from the event receiver. If other records associated with the pulse use the same TSE field then
> they and the waveform record will have exactly the same time stamp for each pulse.
> > If the driver is indeed asyn, we like the proposal for getting the pulseID that you mention above.
> > I wonder how Jeff Hill (LANL) will correlate his data at LANSCE?
> Eric Norum
> [email protected]
- Re: Proposed change in asyn - request for comments Eric Norum
- RE: Proposed change in asyn - request for comments Allison, Stephanie
- Proposed change in asyn - request for comments Mark Rivers
- Re: Proposed change in asyn - request for comments Ernest L. Williams Jr.
- RE: Proposed change in asyn - request for comments Mark Rivers
Re: calc VAL field not updating from bi VAL field J. Lewis Muir
Re: calc VAL field not updating from bi VAL field Tim Mooney
<2012>
<2012>
