1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Proposed change in asyn - request for comments
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 30 May 2012 11:33:58 -0700
When you say, "have the TSE be accurate", do you mean "have the time (obtained from the event system and corresponding to the most recent arrival of the event whose number is in the record TSE field) be accurate"?
The TSE field doesn't hold a time value -- it merely specifies the source from which a time value is to be obtained.
On May 30, 2012, at 10:23 AM, Mark Rivers wrote:
> I'm not sure I understand this.  I am supposing that the areaDetector acquisition can keep up, but that there is a pipeline delay.  If the image frames are tagged at the moment they are acquired the TSE should be valid, even though by the time the records process it may not be the same pulse.  Wouldn't it be useful to have the TSE be accurate for such PVs even if they don't finish processing until 1 or more events later?
> Mark
Eric Norum
[email protected]
Proposed change in asyn - request for comments Mark Rivers
Re: Proposed change in asyn - request for comments Ernest L. Williams Jr.
Re: Proposed change in asyn - request for comments Eric Norum
RE: Proposed change in asyn - request for comments Mark Rivers
RE: Proposed change in asyn - request for comments Allison, Stephanie
Prev: RE: ether_ip problem reading DINT arrays Dudley, David
Next: Re: calc VAL field not updating from bi VAL field Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Proposed change in asyn - request for comments Mark Rivers
Next: RE: Proposed change in asyn - request for comments Allison, Stephanie
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
