Pavel:
We must be talking about different things. If your waveform is 2500
points, and takes 73.5 KB, that works out to 29.4 bytes per point.
Sounds like very high resolution! Even if that waveform was transferred
in some ASCII format, that is still very verbose.
I've never tried to measure the GPIB throughput, but I am fairly certain
that the overall throughput in any case that I've encountered is limited
by the scope itself, and the operation of the scope in terms of its
triggering setup and the signal it is measuring. On some scopes (eg TDS
380), I can swamp it's CPU with GPIB communications, and effectively
cripple its functionality. That is an old scope, and I doubt that modern
scopes would be similarly afflicted. Perhaps the hardcopy function would
be a good case for a throughput test.
--- rod.
Pavel Masloff wrote:
Hi Rod,
We have 2500 points per waveform. Our PCs are equipped with COM ports
only, no GPIB cards. One waveform is 73,5 KB to be exact. The RS232
connection speed is maximum 19200 Kb/s at maximum. For the time being I
just want to check whether the experiment went fine, no false
triggering, etc. In the future, I would like to analyze the waveforms in
matlab via CA. So this will be handy.
What is the speed of the GPIB interface on Tek scopes, anyway?
On Fri, May 4, 2012 at 1:42 AM, Rod Nussbaumer <bomr@triumf.ca
<mailto:bomr@triumf.ca>> wrote:
Pavel:
Every Tektronix scope I've set up communications with had a 500
point waveform (as well as some substantially larger ones).
Presently, I'm acquiring those at 10 waveforms per second (over
GPIB). Are you sure that would not suffice for you? Is GPIB an
option? Much much faster.
--- rod.
Mark,
A waveform weighs 70kB. 4 waveforms = 280 kB. 280 vs 40. I would
have to
wait a couple of minutes till the data is processed. 10-15
seconds for
the screen dmp.
On Thu, May 3, 2012 at 11:13 PM, Mark Rivers
<rivers@cars.uchicago.edu <mailto:rivers@cars.uchicago.edu>
<mailto:rivers@cars.uchicago.__edu
<mailto:rivers@cars.uchicago.edu>>> wrote:
It may be time to back up a step. Why not transfer the
waveforms
themselves, rather than a screen dump? There are others in the
EPICS community who have already done that for the scopes
you are using.
__ __
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
- RE: [Scopes] BMP image record?? Mark Rivers
- [Scopes] BMP image record?? Pavel Masloff
- Re: [Scopes] BMP image record?? Dirk Zimoch
- Re: [Scopes] BMP image record?? Pavel Masloff
- Re: [Scopes] BMP image record?? Rod Nussbaumer
Problem installing CA for QT manta santosh aditya santosh_aditya
Re: ioc with genSub record: compiling error Eric Norum
<2012>
<2012>
ANJ, 27 Nov 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
