1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Scopes] BMP image record??
To: Pavel Masloff <[email protected]>
Date: Thu, 03 May 2012 14:42:47 -0700
Pavel:
Every Tektronix scope I've set up communications with had a 500 point waveform (as well as some substantially larger ones). Presently, I'm acquiring those at 10 waveforms per second (over GPIB). Are you sure that would not suffice for you? Is GPIB an option? Much much faster.
   ---   rod.
Pavel Masloff wrote:
Mark,
A waveform weighs 70kB. 4 waveforms = 280 kB. 280 vs 40. I would have to
wait a couple of minutes till the data is processed. 10-15 seconds for
the screen dmp.
On Thu, May 3, 2012 at 11:13 PM, Mark Rivers <[email protected]
<mailto:[email protected]>> wrote:
    It may be time to back up a step.  Why not transfer the waveforms
    themselves, rather than a screen dump?  There are others in the
    EPICS community who have already done that for the scopes you are using.
    __ __
Re: [Scopes] BMP image record?? Pavel Masloff
Re: [Scopes] BMP image record?? Dirk Zimoch
RE: [Scopes] BMP image record?? Mark Rivers
Prev: Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
Next: Re: [Scopes] BMP image record?? Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [Scopes] BMP image record?? Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
