Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Subject: RE: labCa build fails on 64 bit Windows
To: <ernesto@slac.stanford.edu>, <strauman@slac.stanford.edu>
Cc: tech-talk@aps.anl.gov
Date: Fri, 4 May 2012 10:44:41 +0000
Hi Ernest
Please can I have the binaries while I work out what's wrong with the Visual Studio 2010 build, I don't have 2008.
James
> -----Original Message-----
> From: Ernest L. Williams Jr. [mailto:ernesto@slac.stanford.edu]
> Sent: 03 May 2012 22:33
> To: Till Straumann
> Cc: Rowland, James (DLSLtd,RAL,DIA); tech-talk@aps.anl.gov
> Subject: Re: labCa build fails on 64 bit Windows
> On 05/03/2012 09:12 AM, Till Straumann wrote:
> > I built it on 64-bit windows7 for matlab 2011a. I don't recall what
> > compiler version
> Hi,
> I used MS Visual Studio 2010
> I can provide binaries as well. :)
> Cheers,
> Ernest.
> > was used. Maybe Ernest can fill us in. He should also have access to
> > the binaries; if you're lucky they work for you.
> > - Till
> > On 05/03/2012 06:06 AM, james.rowland@diamond.ac.uk wrote:
> >> Hi
> >> Has anyone got labCa 3.4 to build on windows-64? If so, what
> >> combination of Matlab, Windows and Compiler are you using. I can't
> >> get it to work with Windows Server 2008, MatlabR2011b, Visual Studio
> >> 2010, EPICS 3.14.12.1
> >> Initially the build fails building ezcaglue with some missing libraries:
> >> link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref
> /release   /MACHINE:X64    c:/ma
> >> tlab2011b/extern/lib/win64/microsoft/libut.lib
> >> c:/matlab2011b/extern/lib/win64/microsoft/libmx.lib c
> :/matlab2011b/extern/lib/win64/microsoft/libmex.lib  /implib:mezcaglue.lib
> /out:mezcaglue.dll
> >>      ini.obj multiEzca.obj ctrlC-polled.obj mglue.obj
> ..\\..\\lib\\windows-x64\\ezcamt.lib  d:\ep
> >> ics\r3.14.12.1\base\\lib\\windows-x64\\ca.lib
> >> d:\epics\r3.14.12.1\base\\lib\\windows-x64\\Com.lib u ser32.lib
> >>      Creating library mezcaglue.lib and object mezcaglue.exp
> >> ca.lib(ca_client_context.obj) : error LNK2001: unresolved external
> >> symbol __imp_bind etc.
> >> Adding ws2_32 and advapi32 to USR_SYS_LIBS fixes this but the mex functions
> fail:
> >> make[2]: Entering directory
> >> `S:/Technical/Controls/Software/Matlab/Build/labca_3_4/matlab/O.windo
> >> ws-
> >> x64'
> >> c:/matlab2011b/bin/mex.bat   -DMATLAB_APP  ../lcaGetNelem.c -I. -
> I../O.Common -I. -I.. -I../../inclu
> >> de/os/WIN32 -I../../include -Id:\epics\r3.14.12.1\base/include/os/WIN32 -
> >> nclude         -I../../ezca -I../../glue      ../../lib/windows-
> x64/mezcaglue.lib  ../../lib/windows
> >> -x64/ezcamt.lib  d:\epics\r3.14.12.1\base/lib/windows-x64/ca.lib
> >> ws-x64/Com.lib  ../../lib/windows-x64/ezcamt.lib
> >> d:\epics\r3.14.12.1\base/lib/windows-x64/ca.lib  d
> >> :\epics\r3.14.12.1\base/lib/windows-x64/Com.lib ws2_32.lib advapi32.lib
> ws2_32.lib advapi32.lib user 32.lib kernel32.lib winmm.lib
> >>      Creating library
> >> C:\Users\jr76\AppData\Local\Temp\3\mex_JqkfYu\templib.x and object
> >> C:\Users\jr76 \AppData\Local\Temp\3\mex_JqkfYu\templib.exp
> >> lcaGetNelem.obj : error LNK2019: unresolved external symbol
> >> __imp_ezcaFree referenced in function me xFunction
> >> lcaGetNelem.mexw64 : fatal error LNK1120: 1 unresolved externals
> >>     C:\MATLAB~1\BIN\MEX.PL: Error: Link of 'lcaGetNelem.mexw64' failed.
> >> make[2]: *** [lcaGetNelem.mexw64] Error 2
> >> make[2]: Leaving directory
> >> ws-x
> >> 64'
> >> make[1]: *** [install.windows-x64] Error 2
> >> make[1]: Leaving directory
> `S:/Technical/Controls/Software/Matlab/Build/labca_3_4/matlab'
> >> make: *** [matlab.install] Error 2
> >> S:\Technical\Controls\Software\Matlab\Build\labca_3_4>
> >> James
Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
labCa build fails on 64 bit Windows james.rowland
Re: labCa build fails on 64 bit Windows Till Straumann
Prev: undefined symbol:MAXvSetup 洪春霞
Next: RE: Trouble compiling areaDetector1-8beta1 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017
Prev: Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
Next: Re: labCa build fails on 64 bit Windows Ernest L. Williams Jr.
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
