Title: undefined symbol:MAXvSetup
Hello,everyone.
Now I have a oms motor and a VME crate. The oms motor application comes from synApps_5_3/support/motor/6-3/motorApp/OmsSrc and my epics base is 3.14.8.2. Now I use the makeBaseApp.pl to produce a new application and copy the source file(MotorSrc and OmsSrc and SoftMotorSrc) to the corresponding directory ,that is to say, in the same directory with Db and src.The **App/Makefile as follows. Now I only modify the **App/src/Makefile, and I have not change anything about MotorSrc and OmsSrc and SoftMotorSrc and their Makefile. The compile is ok.
But when I download st.cmd to the VME crate, there are some problems. It is said the MAXvSetup is an undefined symbol. The error message is as follows.
Can anyone help with this problem please?
Thank you very much.
----------------------**App/Makefile-------------------------------------------------------------------------------
TOP = ..
include $(TOP)/configure/CONFIG
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *src*))
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *Src*))
DIRS += MotorSrc
DIRS += OmsSrc
DIRS += SoftMotorSrc
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *db*))
DIRS := $(DIRS) $(filter-out $(DIRS), $(wildcard *Db*))
include $(TOP)/configure/RULES_DIRS
----------------------**App/src/Makefile------------------------------------------------------------------------------
TOP=../..
# ADD MACRO DEFINITIONS AFTER THIS LINE
# Build an IOC support library
LIBRARY_IOC += xxxSupport
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += xxxRecord
# install devXxxSoft.dbd into <top>/dbd
DBD += xxxSupport.dbd
# The following are compiled and added to the Support library
xxxSupport_SRCS += xxxRecord.c
xxxSupport_SRCS += devXxxSoft.c
xxxSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# build an ioc application
PROD_IOC = bisaxsioc
# bisaxsioc.dbd will be created and installed
DBD += bisaxsioc.dbd
# bisaxsioc.dbd will be made up from these files:
bisaxsioc_DBD += base.dbd
bisaxsioc_DBD += xxxSupport.dbd
bisaxsioc_DBD += dbSubExample.dbd
bisaxsioc_DBD += bisaxsiocHello.dbd
bisaxsioc_DBD += asyn.dbd
bisaxsioc_DBD += oms.dbd
bisaxsioc_DBD += motorSupport.dbd
bisaxsioc_DBD += motorRecord.dbd
bisaxsioc_DBD += devOms.dbd
bisaxsioc_DBD += devSoftMotor.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
bisaxsioc_SRCS += bisaxsioc_registerRecordDeviceDriver.cpp
bisaxsioc_SRCS_DEFAULT += bisaxsiocMain.cpp
bisaxsioc_SRCS_vxWorks += -nil-
# Add locally compiled object code
bisaxsioc_SRCS += dbSubExample.c
bisaxsioc_SRCS += bisaxsiocHello.c
# The following adds support from base/src/vxWorks
bisaxsioc_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
bisaxsioc_LIBS += xxxSupport
bisaxsioc_LIBS += asyn
bisaxsioc_LIBS += motor
bisaxsioc_LIBS += softMotor
bisaxsioc_LIBS += oms
# NOTE: To build SNL programs, SNCSEQ must be defined
# in the <top>/configure/RELEASE file
ifneq ($(SNCSEQ),)
# This builds sncExample as a component of bisaxsioc
bisaxsioc_SNCFLAGS += +r
bisaxsioc_DBD += sncExample.dbd
bisaxsioc_SRCS += sncExample.stt
bisaxsioc_LIBS += seq pv
# The following builds sncProgram as a standalone application
PROD_HOST += sncProgram
sncProgram_SNCFLAGS += +m
sncProgram_SRCS += sncProgram.st
sncProgram_LIBS += seq pv
sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
bisaxsioc_LIBS += $(EPICS_BASE_IOC_LIBS)
# ADD RULES AFTER THIS LINE
----------------------st.cmd------------------------------------------------------------------------------
## Example vxWorks startup file
## The following is needed if your board support package doesn't at boot time
## automatically cd to the directory containing its startup script
cd "/home/blctrl/bisaxs/bisaxsioc/iocBoot/iocbisaxsioc"
< cdCommands
#< ../nfsCommands
cd topbin
## You may have to change bisaxsioc to something else
## everywhere it appears in this file
#cd "/home/blctrl/bisaxs/bisaxsioc/bin/vxWorks-ppc604_long"
sysCplusEnable=1
ld < bisaxsioc.munch
## This drvTS initializer is needed if the IOC has a hardware event system
#TSinit
cd top
dbLoadDatabase("dbd/bisaxsioc.dbd")
#dbLoadDatabase("dbd/bisaxsioc.dbd",0,0)
bisaxsioc_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("db/beamstop.db")
MAXvSetup(1,16,0xF000,190,5,10)
drvMAXvdebug=4
config0="AA LH1,1,1,1,1,1,1,1 PSO;AA HH1,1,1,1,1,1,1,1;AA AF1,1,1,1,1,1,1,1;"
MAXvConfig(0, config0)
## Load record instances
#dbLoadRecords("db/dbExample1.db","user=blctrl")
#dbLoadRecords("db/dbExample2.db","user=blctrl,no=1,scan=1 second")
#dbLoadRecords("db/dbExample2.db","user=blctrl,no=2,scan=2 second")
#dbLoadRecords("db/dbExample2.db","user=blctrl,no=3,scan=5 second")
#dbLoadRecords("db/dbSubExample.db","user=blctrl")
## Set this to see messages from mySub
#mySubDebug = 1
cd startup
shellPromptSet "BL16B1> "
iocLogDisable=1
iocInit
#iocInit()
## Start any sequence programs
#seq &sncExample,"user=blctrl"
----------------------error messages------------------------------------------------------------------------------
sysAtReboot not found. epicsExit will not be called by reboot.
value = 516329056 = 0x1ec68e60
cd top
value = 0 = 0x0
value = 0 = 0x0
value = 0 = 0x0
Error Last token ")"
input line: record(motor,“X16B1:EH:BS:TRX”)
in: file db/beamstop.db line 2
db_parse returned -1
value=-1=0xffffffff
undefined symbol: MAXvSetup
filename="../dbLexRoutines.c" line number=910
Record Type does not exist dbFindRecordType
hongchunxia
No.239 Zhangheng Road
PuDong District
Shanghai Institute of Applied Physics CAS
Shanghai, China
- Re: undefined symbol:MAXvSetup Michael Davidsaver
- RE: undefined symbol:MAXvSetup Mark Rivers
Re: [Scopes] BMP image record?? Dirk Zimoch
RE: labCa build fails on 64 bit Windows james.rowland
<2012>
RE: Trouble compiling areaDetector1-8beta1 Mark Rivers
<2012>
