g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: [Scopes] BMP image record??
To: Eric Norum <eric@norum.ca>
Cc: EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Thu, 3 May 2012 11:22:08 +0400
Every time now I get this message:
L1 TPS2024B:file: 3574 bytes surplus input "<00><00><00><00><00><00>6<04><00><00>(<00><00><00>@<01><00><00>Ё<00>..."
L1 TPS2024B:file: after 4 bytes: "BM<92>/"
The amount of bytes (3574 in this example) varies from time to time (as I set a different readTimeout), but the second line saying "after 4 bytes: "BM<92>/" remains the same.
Strange...
On Thu, May 3, 2012 at 8:56 AM, Eric Norum <eric@norum.ca> wrote:
Looks reasonable.
Please post your results.
You might make the ReadTimeout a little longer since the only negative effect is that it will take a little longer for the transfer to complete.   The postive effect is that the chance of receiving a partial image is reduced.
On May 2, 2012, at 9:33 PM, Pavel Masloff wrote:
> The minimum gap time is about 0,3 s. I checked it with the Python script. Sometimes, I got only the bottom part of the image, So I increased the sleep time from 0,3 to 0,5 seconds.
> So, Eric, I should try something like this (with nnn = the maximum expected file size in bytes which in my case is sth about 50 kB):
> PrtScr {
>       InTerminator = "";
>       ReplyTimeout = 2000;
>       ReadTimeout = 500;
>       out "HARDCOPY START";
>       in "%50000c";
> So, if the file is ~ 14 kB, it will copy 14 kB then the ReadTimeout will elapse, and it's done. Correct?
Eric Norum
eric@norum.ca
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Re: [Scopes] BMP image record?? Pavel Masloff
RE: [Scopes] BMP image record?? Mark Rivers
Re: [Scopes] BMP image record?? Rod Nussbaumer
Re: [Scopes] BMP image record?? Eric Norum
Prev: Regarding access of Process Variable manta santosh aditya santosh_aditya
Next: Re: [Scopes] BMP image record?? Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: [Scopes] BMP image record?? Pavel Masloff
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
