1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Scopes] BMP image record??
Date: Sun, 29 Apr 2012 20:18:18 +0400
Why can't I?
In Hyperterminal (as well as in Python) you simply send a command and receive bytes, which you forward to a binary file. Sth like this:
import sys
import os
import time
import serial
# create target file
print os.getcwd()
f = open('hardcopy.png', 'wb')
# configure the serial connection
ser = serial.Serial()
ser.port = 0
ser.timeout = 0
ser.baudrate = 9600
ser.open()
# configure the hardcopy settings
cmd = ':HARDCOPY:FORMAT PNG;PALETTE NORMAL;PORT RS232;LAYOUT PORTRAIT;\
PREVIEW 0;INKSAVER 0;COMPRESSION 0\n'
a = ser.write(cmd)
print "bytes sent: {:d}".format(a)
# start hardcopy
a = ser.write("HARDCOPY START\n")
# begin receiving data and writing to file
total_bytes = 0;
a = ser.inWaiting()
while a>0:
    time.sleep(0.5)
    data = "">    total_bytes += a
    f.write(data)
    time.sleep(0.5)
    a = ser.inWaiting()
    sys.stdout.write(".")
# close file and serial port
sys.stdout.write("\n")
f.close()
ser.close()
print "bytes read: {:d}".format(total_bytes)
print "script completed"
Are you sure StreamDevice won't write the input to a waveform record?
On Sun, Apr 29, 2012 at 7:47 PM, Mark Rivers <[email protected]> wrote:
I don't think you can get the image into a waveform record from the scope with StreamDevice.  You would have to write another driver that does what you were doing with Hyperterminal and Python.  You could perhaps use an SNL program for this.
To display an image in BOY you use the Intensity Plot widget.  The waveform record is 1-D, but you tell the BOY widget the actual X and Y dimensions of the array.
Sent: Sunday, April 29, 2012 9:22 AM
To: Mark Rivers
Cc: EPICS Tech Talk
Is there any working example on how to get the image into a waveform record using StreamDevice? I haven't used the waveform record yet, reading up on this in the db reference manual, not that comprehensible :(
Another question is how to read a waveform (image type) in BOY?
Pavel
On Sat, Apr 28, 2012 at 5:53 PM, Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
If you can get the image into a waveform record, using streamDevice for example, then you can display that waveform as in image in EDM, CSS BOY, ImageJ or other applications.  You need to create a few other records that tell the client what the actual image dimensions are.
It may be just as easy to implement reading the actual waveforms into waveform records, and display those with Cartesian plot widgets in your display manager.
From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] on behalf of Pavel Masloff [[email protected]<mailto:[email protected]>]
Sent: Saturday, April 28, 2012 2:17 AM
To: EPICS Tech Talk
Subject: [Scopes] BMP image record??
Hello again,
As I mentioned earlier we are running a series of experiments with our high current switches. I have written simple support ("...with a little help from my friend" Dirk Zimoch) for the Tektronix TPS2000 over RS232 using StreamDevice and ASYN, so now I can remotely arm the scopes, set its properties, save waveforms on to the CF card, etc. But...
In order to not run back and forth and see if everything went OK (which is rather tiresome and time consuming), we need a confirmation from the scopes. I don't want to deal with the implementation of the waveform records for now, all I have got so far is that I save them on the flash card.
As such a confirmation I see transferring the BMP (or PNG) image from the scope (sort of Print screen) on to the operator PC somehow.
There is a special SCPI command "Hardcopy start". Which mimics the Print button on the scope's front panel. I have tried to transfer a BMP file via Hyperterminal (and Python script) and it worked out well (more or less).
How could this be ported to the EPICS database from the IOC and client standpoint, so an operator could see the oscillogram on the screen and decide whether the experiment went well, so she will save the waveforms and move on to the next experiment?
The image file is maximum ~ 46Kb (20Kb on average).
Any thoughts?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Best regards,
Pavel Maslov, MS
Re: [Scopes] BMP image record?? Rod Nussbaumer
RE: [Scopes] BMP image record?? Mark Rivers
[Scopes] BMP image record?? Pavel Masloff
Re: [Scopes] BMP image record?? Pavel Masloff
Prev: RE: [Scopes] BMP image record?? Mark Rivers
Next: Re: [Scopes] BMP image record?? Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
