1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: does CSS (CAJ?) support CA over an ssh tunnel
To: [email protected]
Date: Mon, 9 Apr 2012 13:55:00 -0500
Hi Peter,
On 2012-04-09 Peter Milne wrote:
> CA tunnelled successfully over ssh:
> (IOC:5064 port forwarded to localhost:10013)
> export EPICS_CA_ADDR_LIST=localhost:10013
> export EPICS_CA_AUTO_ADDR_LIST=no
> export EPICS_CA_NAME_SERVERS=localhost:10013
> camonitor cpsc_011_UPTIME
> cpsc_011_UPTIME 2012-04-09 19:02:06.116235 107056
> cpsc_011_UPTIME 2012-04-09 19:02:07.116355 107057
> But on running css from the same shell session with the same exported
> variables, it's unable to see the PV
> => Is it possible to view a tunneled PV from CSS?.
Does your CSS have JCA configured to use the Pure Java implementation of the
CA client code, or the JNI implementation that calls OS-specific?  You can
find that under Preferences => CSS Core => EPICS.
I suspect the pure Java implementation of JCA doesn't have the ability to make
TCP-only connections (added to Base in 3.14.12) which is required to tunnel CA
over ssh. It should be possible to fix that by switching to JNI as long as the
native libraries it uses are from Base-3.14.12 or later.  Unfortunately I also
suspect the CSS distributions have not updated those Base libraries recently,
so you might have some difficulties with this unless you build your own
package.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: does CSS (CAJ?) support CA over an ssh tunnel Peter Milne
Prev: Re: does CSS (CAJ?) support CA over an ssh tunnel Kasemir, Kay
Next: Re: does CSS (CAJ?) support CA over an ssh tunnel Peter Milne
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
