1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: AW: Connection to Siemens S7 PLC
To: [email protected] <[email protected]>
Date: Fri, 23 Mar 2012 12:12:09 +0100
This topic is a few weeks old already but for your information, sometimes 'All is well that ends well':
Our connection handling problem is solved after some help of the Siemens support. Interfacing with the SLS S7 driver to a Siemens PLC directly connecting to a CPU315-2 PN/DP works fine now.
The problem we had was a timing issue. Most likely the PLC tried to initialize functions to quickly after booting. That made the TCON function got locked sometimes.
HTH,
Jens
> -----Ursprüngliche Nachricht-----
> Von: [email protected] [mailto:tech-talk-
> [email protected]] Im Auftrag von Rod Nussbaumer
> Gesendet: Mittwoch, 22. Februar 2012 18:20
> An: Konrad Gajewski
> Cc: [email protected]
> Betreff: Re: Connection to Siemens S7 PLC
> At TRIUMF, we are using our own driver to talk to 400-series Siemens
> PLCs. It uses asyn, and was modeled after Mark Rivers' modbus PLC
> driver. The underlying communications protocol is the Siemens
> FETCH/WRITE protocol over TCP/IP.
> Rod Nussbaumer
> ISAC Controls, TRIUMF
> Vancouver, Canada
> Konrad Gajewski wrote:
> > Hello everybody,
> > I'm new to EPICS and I am planning to control Siemens Simatic S7-200
> > PLC. I have looked in EPIC documentation and found at least two ways
> to
> > connect the PLC:
> > 1. via MODBUS (Asyn) driver over the serial connection (using Siemens
> > MODBUS RTU library)
> > 2. using S7plc driver via TCP/IP and a CP 243-1 Ethernet module.
> > The programming of the PLC is done using Step-7 Micro/WIN V4.0.
> > Unfortunately I can't open the example STEP 7 PLC project (for S7plc
> > driver) in Step-7 Micro/WIN.
> > Do you have any experience with such a configuration or maybe with
> > S7-1200? Are there any better options?
> > Thanks,
> > Konrad
Re: AW: Connection to Siemens S7 PLC Konrad Gajewski
Re: Connection to Siemens S7 PLC Rod Nussbaumer
Prev: Re: list of pv aliases djquock
Next: Re: AW: Connection to Siemens S7 PLC Konrad Gajewski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Connection to Siemens S7 PLC Rod Nussbaumer
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
