1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS workspace lock, prompt Re: BOY FAQ
To: Ralph Lange <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 2 Mar 2012 10:47:30 -0500
On 3/2/12 10:29 , "Ralph Lange" <[email protected]> wrote:
>>* your preferences modifications
>You also lose the setup of all imported projects from shared locations,
>linked directories, etc.
This is again a question of how you want to handle it:
Where do you put "shared" files, like *.opi or Data Browser configs?
You can put your "global" *.opi files onto a web server,
and add the links to them to the "Top OPIs" menu.
That way, every user always has access to the most
recent version, no need to copy them into the workspace.
Plus they're automatically read-only.
For things that you want to reach as files, maybe allow
editing based on the usual file permissions,
a linked directory is good, but then there's the question
of how each user gets the appropriate link into their workspace.
In the SNS control room we start CSS with a command-line
option
  -share_link /path/to/some/folder
It creates a linked directory for that folder in the user's workspace.
The folder is some NFS location with subdirectories
for common OPIs, PACE configs etc.
That way nobody needs to manually create the linked folder.
You can start with a 'blank' workspace; you'll get the link.
We currently, however, support only a single -share_link option,
so everything must be in subdirectories of that one NFS location.
Kay
Re: CSS workspace lock, prompt Re: BOY FAQ Ralph Lange
Prev: Re: CSS workspace lock, prompt Re: BOY FAQ Ralph Lange
Next: "Size of symbol changed" warnings building EPICS Base 3.14.12.2 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: CSS workspace lock, prompt Re: BOY FAQ Michael Davidsaver
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
