Hi Mark,
I've had a similar experience with a chain of West 2300 temperature monitors (also serial RTU on RS-485). In my case the IOC was running on vxWorks, but like Ralph I was seeing persistent modbus CRC errors on the IOC console, although the data itself was good. I thought it was probably something wrong in my setup but didn't have time to do much investigation.
Emma
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: Friday, 2 March 2012 4:47 AM
To: 'Ralph Lange'; EPICS Tech Talk
Subject: RE: CRC issues using Modbus/asyn on 64bit Linux
I should add that the CRC is only used on Modbus serial RTU, not on Modbus TCP or Modbus serial ASCII.
So 2 questions:
1) Has anyone successfully run Modbus/asyn serial RTU on 64bit Linux?
2) Has anyone run the Wave P6100 temperature controller with Modbus/asyn serial RTU on any architecture?
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: Thursday, March 01, 2012 11:30 AM
To: EPICS Tech Talk
Subject: CRC issues using Modbus/asyn on 64bit Linux
I am reliably getting CRC errors on the device's answer when reading
more than two parameters (Modbus code 3) through serial RTU on RS-485
from a Wave P6100 temperature controller. The data itself looks good and
reasonable.
One or two word access (Modbus code 1 or 3) seems to work fine.
The IOC runs on 64bit Linux, using Mark Rivers' Modbus on ASYN driver.
(All from synApps 5.5)
Has anyone seen similar behaviour?
Does anyone successfully run Modbus/asyn on 64bit Linux? (To rule out 64
bit issues in the CRC checking part.)
Thanks for any help,
~Ralph
<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
- RE: CRC issues using Modbus/asyn on 64bit Linux Mark Rivers
- CRC issues using Modbus/asyn on 64bit Linux Ralph Lange
Re: BOY FAQ Benjamin Franksen
<2012>
<2012>
