g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: Setting macro value from commandline
To: "Xinyu.Wu@csiro.au" <Xinyu.Wu@csiro.au>, "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Mon, 27 Feb 2012 09:06:46 -0500
Hi:
You can set macros at these levels:
1.BOY Runtime Preference Setting (-pluginCustomization ...)
2.User Preference settings (Menu Edit, Preferences, CSS Applications,
Display, BOY, OPI Runtime)
3.Macro parameter of Action that opens the *.opi file
4.Display *.opi file property "Macros"
5.Grouping/Linking/Tabbed Container that wraps the widgets
Setting a macro within an Action overrides settings from
the user preferences.
Setting them within the Grouping container overrides
those from the Action and so on.
The first option is basically the command line:
You can define any setting for CSS in a plugin customization file
that has the format
# Comment
plugin.name/setting_name=value
For example:
# BOY Macros, format
# macro1,value1|macro2,"value 2"|macro3,"another value"
org.csstudio.opibuilder/macros=MyMacro1,"value 1"|MyOtherMacro,"Another
Value"
# EPICS Settings
org.csstudio.platform.libs.epics/addr_list=127.0.0.1 123.45.67.89
The format of the settings available for BOY
are in the file org.csstudio.opibuilder/preferences.ini.
The format of the settings available for EPICS Channel Access
are in the file org.csstudio.platform.libs.epics/preferences.ini.
The format of the settings for plugin ABC
should be in a file ABC//preferences.ini.
You put all those defaults that you want into a file
my_plugin_customization.ini
and then start CSS with the command-line option
   css -pluginCustomization /path/to/my_plugin_customization.ini
See also chapter "Hierarchical Preferences"
in http://cs-studio.sourceforge.net/docbook/css_book.pdf
-Kay
On 2/26/12 17:31 , "Xinyu.Wu@csiro.au" <Xinyu.Wu@csiro.au> wrote:
>Sorry, I mean how do you set macro values from the command line for BOY.
>(I'm new to EPICS and BOY. )
>Thanks
>Xinyu
>On 27/02/2012, at 4:22 AM, Eric Norum wrote:
>> When starting a soft IOC you can set the value of iocsh variables from
>>shell environment variables using the epicsEnvSet iocsh command like
>>this:
>> epicsEnvSet(KEITHLEY2400_ETHERNET,
>>"$(KEITHLEY2400_ETHERNET=164.54.49.10:4001)")
>> So, if you start the IOC like this:
>> ./st.cmd
>> the iocsh KEITHLEY2400_ETHERNET variable will be set to
>>164.54.49.10:4001
>> but if you start the IOC like this:
>> KEITHLEY2400_ETHERNET=192.168.1.2 ./st.cmd
>> the  iocsh KEITHLEY2400_ETHERNET variable will be set to 192.168.1.2
>> The '=' part to supply a default value can be omitted if you like.
>> On Feb 26, 2012, at 2:20 AM, <Xinyu.Wu@csiro.au> wrote:
>>> Hi,
>>> The documentation seems to imply that you can set macro values from
>>>the command line. Can anyone tell me how to do it please?
>>> Thanks
>>> Xinyu WU
>>> ASKAP Computing
>>> Australia Telescope National Facility
>>> CSIRO Astronomy and Space Science
>>> phone: +61 2 9372 4727
>>> postal: PO Box 76 Epping, NSW. 1710
>> Eric Norum
>> eric@norum.ca
>Xinyu WU
>ASKAP Computing
RE: Setting macro value from commandline Chen, Xihui
Re: Setting macro value from commandline Xinyu.Wu
Prev: Sequencer build rules Benjamin Franksen
Next: Re: Access PV from JavaScript in BOY Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: Setting macro value from commandline Xinyu.Wu
Next: RE: Setting macro value from commandline Chen, Xihui
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
