Hi Xinyu,
I guess you are asking about open BOY OPI files from command line. For that, you can input macros to the OPI files like this:
Input Macros from command line
When you startup css from command line, you can specify the OPI files you want to run and their macros input:
css --launcher.openFile "<path_to_opi>/file1.opi macro1=value1, macro2=value2" "<path_to_opi2>/file2.opi"
It also allows embedding [\ascii-code] in macros when inputting macros from command line. For example:
css --launcher.openFile "<path_to_opi>/file1.opi macro1=A[\58]B, macro2=value2" "<path_to_opi2>/file2.opi"
In above example, the value of macro1 is A:B.
If there is already a CSS instance running, it will open the OPIs in the running CSS. The option --launcher.openFile is not necessary if following lines were added to css.ini:
--launcher.defaultAction
openFile
Note1: For Linux GTK, ":" is not allowed in macros. Instead using [\58].
Note2: To make this command line work for Linux machine, you may need to add follow lines to your css.ini which is under your CSS directory (this line should be added before -vmargs):
You may able to find the path to libjvm.so by using command locate libjvm.so See https://bugs.eclipse.org/bugs/show_bug.cgi?id=331122
Xihui
> -----Original Message-----
> From: Kasemir, Kay [mailto:[email protected]]
> Sent: Monday, February 27, 2012 9:07 AM
> To: [email protected]; [email protected]
> Subject: Re: Setting macro value from commandline
> Hi:
> You can set macros at these levels:
> 1.BOY Runtime Preference Setting (-pluginCustomization ...)
> 2.User Preference settings (Menu Edit, Preferences, CSS Applications,
> Display, BOY, OPI Runtime)
> 3.Macro parameter of Action that opens the *.opi file
> 4.Display *.opi file property "Macros"
> 5.Grouping/Linking/Tabbed Container that wraps the widgets
> Setting a macro within an Action overrides settings from
> the user preferences.
> Setting them within the Grouping container overrides
> those from the Action and so on.
> The first option is basically the command line:
> You can define any setting for CSS in a plugin customization file
> that has the format
> # Comment
> plugin.name/setting_name=value
> For example:
> # BOY Macros, format
> # macro1,value1|macro2,"value 2"|macro3,"another value"
> org.csstudio.opibuilder/macros=MyMacro1,"value 1"|MyOtherMacro,"Another
> Value"
> # EPICS Settings
> org.csstudio.platform.libs.epics/addr_list=127.0.0.1 123.45.67.89
> The format of the settings available for BOY
> are in the file org.csstudio.opibuilder/preferences.ini.
> The format of the settings available for EPICS Channel Access
> are in the file org.csstudio.platform.libs.epics/preferences.ini.
> The format of the settings for plugin ABC
> should be in a file ABC//preferences.ini.
> You put all those defaults that you want into a file
> my_plugin_customization.ini
> and then start CSS with the command-line option
> css -pluginCustomization /path/to/my_plugin_customization.ini
> See also chapter "Hierarchical Preferences"
> in http://cs-studio.sourceforge.net/docbook/css_book.pdf
> Thanks,
> -Kay
> On 2/26/12 17:31 , "[email protected]" <[email protected]> wrote:
> >Sorry, I mean how do you set macro values from the command line for
> BOY.
> >(I'm new to EPICS and BOY. )
> >Thanks
> >Xinyu
> >On 27/02/2012, at 4:22 AM, Eric Norum wrote:
> >> When starting a soft IOC you can set the value of iocsh variables
> from
> >>shell environment variables using the epicsEnvSet iocsh command like
> >>this:
> >> epicsEnvSet(KEITHLEY2400_ETHERNET,
> >>"$(KEITHLEY2400_ETHERNET=164.54.49.10:4001)")
> >> So, if you start the IOC like this:
> >> ./st.cmd
> >> the iocsh KEITHLEY2400_ETHERNET variable will be set to
> >>164.54.49.10:4001
> >> but if you start the IOC like this:
> >> KEITHLEY2400_ETHERNET=192.168.1.2 ./st.cmd
> >> the iocsh KEITHLEY2400_ETHERNET variable will be set to 192.168.1.2
> >> The '=' part to supply a default value can be omitted if you like.
> >> On Feb 26, 2012, at 2:20 AM, <[email protected]> wrote:
> >>> Hi,
> >>> The documentation seems to imply that you can set macro values from
> >>>the command line. Can anyone tell me how to do it please?
> >>> Thanks
> >>> Xinyu WU
> >>> ASKAP Computing
> >>> Australia Telescope National Facility
> >>> CSIRO Astronomy and Space Science
> >>> phone: +61 2 9372 4727
> >>> postal: PO Box 76 Epping, NSW. 1710
> >> Eric Norum
> >> [email protected]
> >Xinyu WU
> >ASKAP Computing
