1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CSS X-Y Graph
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Fri, 24 Feb 2012 12:22:51 -0500
Andrew,
This works for me with the following caveat. If the number of points in the waveform becomes greater than the number of points when the MEDM screen began execution the display does not adjust. It handles reducing the number of points and then increasing back to the original number but if I want to exceed the number of points that was in effect when the screen began execution I have to switch to Edit and then back to Execute.
Is this what I should expect?
John Dobbins
On 2/21/2012 7:45 PM, Eric Norum wrote:
MEDM supports variable-length waveform plots -- set the "Count Num or Channel" to the PV holding the number of points.  I usually work around the no-monitors-on-NORD problem by forward linking my waveform records to a longin record that gets its value from the waveform NORD field -- I then set the MEDM "Count Num or Channel" to that longin record -- which does post monitors on changes.  This latter problem will be moot on arrival of 3.15, of course.
On Feb 21, 2012, at 4:36 PM, John Dobbins wrote:
Andrew,
I don't know if this matters but my waveform is actually one of the outputs of a genSub record. It has a NOVA field but I could alternately use another output as a array length indicator field.
BTW, I am also open to doing this in EDM or MEDM or ???
John Dobbins
On 2/21/2012 7:17 PM, Andrew Johnson wrote:
Hi Michael,
On 2012-02-21 Michael Davidsaver wrote:
I too have had trouble doing this.  I was able to setup a rule to set
the buffer size from the NORD field of a waveform record.  The result
was that, when the size was reduced, the start of the waveform was
removed instead of the end.  So not very useful.
Also note that the NORD field of a waveform record does not get monitors
posted on it unless there is device support that explicitly does that, so this
wouldn't necessarily work too well anyway (you could forward-link the waveform
record to a longin that reads the NORD field and use that instead though).
In 3.15 any device support will still be responsible for posting monitors if
it sets NORD, but the record and soft device support will also do it when they
set NORD.
- Andrew
Re: CSS X-Y Graph Andrew Johnson
CSS X-Y Graph John Dobbins
Re: CSS X-Y Graph Michael Davidsaver
Re: CSS X-Y Graph John Dobbins
Re: CSS X-Y Graph Eric Norum
Prev: RE: QT-based tools: Expressions of interest requested Paul.gibbons
Next: Re: QT-based tools: Expressions of interest requested Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CSS X-Y Graph Eric Norum
Next: Re: CSS X-Y Graph Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
