Hello John,
I too have had trouble doing this. I was able to setup a rule to set
the buffer size from the NORD field of a waveform record. The result
was that, when the size was reduced, the start of the waveform was
removed instead of the end. So not very useful.
In the end, as this data was for display only, I "fixed" this by padding
the arrays by repeating the last value. This at least produces the
correct visual effect.
I would welcome a better solution.
Michael
On 2/21/2012 4:45 PM, John Dobbins wrote:
All,
I am trying to create an X-Y graph for displaying a waveform which may change in length.
A Tech-Talk thread from June 2010
http://www.aps.anl.gov/epics/tech-talk/2010/msg00740.php
suggests to put a PV into "Buffer Size" . However I am trying to do that now (CSS 3.1) and find I can only put an integer into this field, not a PV.
Taking a step back, is there a recommended approach for displaying a waveform which may vary in size. I would like the plot x scale to automatically adjust to the new waveform length.
John Dobbins
Cornell University
- Re: CSS X-Y Graph Andrew Johnson
- RE: CSS X-Y Graph Chen, Xihui
- CSS X-Y Graph John Dobbins
RE: QT-based tools: Expressions of interest requested Szalata, Zenon M.
<2012>
<2012>
