g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: odd behavior of 'dbpf' on windows softioc
To: tech-talk@aps.anl.gov
Date: Thu, 26 Jan 2012 18:16:42 -0600
Hi Josh,
On 2012-01-25 Josh Stein wrote:
> This does not seem to function properly on my 3.14.11 Windows softIOC:
> epics>dbpf "wst:v13C","1"
> Illegal choice PV: wst:v13C  1
> filename="../dbTest.c" line number=333
> Illegal choice - dbPutField error
> Is this a feature, flaw, or user error on my part?
This is a combination of a minor bug in dbpf that I introduced into R3.14.10
and a problem with sscanf() from the MinGW C run-time library which you were
using.  Mark does not see the issue because he's probably using a win32-x86
target while you're using win32-x86-mingw. The dbpf bug gets masked by the IOC
performing the conversion elsewhere, except this particular sscanf() bug
caused that conversion to fail as well.
I've added a patch to the R3.14.12 Known Problems page which fixes both of
these.  The patch can also be applied to fix this problem in earlier versions
of Base back to R3.14.10, although I haven't tried that and you might have to
make the changes manually in some cases.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
odd behavior of 'dbpf' on windows softioc Josh Stein
Prev: RE: Struck SIS3302 device driver Hu, Yong
Next: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: RE: odd behavior of 'dbpf' on windows softioc Mark Rivers
Next: Struck SIS3302 device driver Chengcheng Xu
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
