1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Motor record support for Galil DMC-2183
To: "[email protected] ([email protected])" <[email protected]>
Date: Wed, 25 Jan 2012 09:26:37 +1100
Hi All,
Hopefully attached, is a copy of a EPICS Galil driver that uses the motor Record.  The driver is updated regularly, so for now, contact me by email for updates.  Soon we will have a website for public access.  So far the driver has worked on all Galil units tested, which includes the following models:
1415
21X3 Series
40x0 Series
RIO Series
The driver uses a config/MASTER_RELEASE build mechansim identical to that used in synApps 5_2, to assist in building the required support modules.  An example config/MASTER_RELEASE, and config/Makefile file is also attached.
An example application is included, and the documentation is mainly in the example st.cmd.  Email bugs reports to me.
Cheers,
Mark Clift.
Dr. Mark Clift
Senior Controls Engineer
Australian Synchrotron
800 Blackburn Road
Clayton 3168
Ph: +613 8540 4264
Fax: +613 8540 4200
Mail: [email protected]<br>This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Attachment: galil_1-4.tar.gz
Description: galil_1-4.tar.gz
Attachment: Makefile
Description: Makefile
Attachment: MASTER_RELEASE
Description: MASTER_RELEASE
Re: Motor record support for Galil DMC-2183 Andrew Johnson
Prev: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Next: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Motor record support for Galil DMC-2183 Emmanuel Mayssat
Next: Re: Motor record support for Galil DMC-2183 Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
