g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: [CSS] 'Epics' menu in Preferences disappeared!!!
To: "Kasemir, Kay" <kasemirk@ornl.gov>
Cc: "tech-talk@aps.anl.gov" <tech-talk@aps.anl.gov>
Date: Wed, 25 Jan 2012 17:17:28 +0300
Yeah, that's right! The bottleneck was the lucene.core plugin which was listed in the dependencies, but was not added to the feature plugin.
Matter fact, in the KEK source files there is an additional feature plugin namely org.csstudio.kek.optional.feature, with Auth&auth and alarms support. I used it. Now it seems to me building your own application in Eclipse using features is not hard whatsoever. One just needs to include all the plugins required (as in Run->run as-> configurations).
Thank you Kay!
Bye,
Pavel
On Wed, Jan 25, 2012 at 12:21 AM, Kasemir, Kay <kasemirk@ornl.gov> wrote:
Hello:
I believe the "lucene" dependencies changed with Eclipse versions.
So depending on which version of Eclipse you are using,
you need those or don't have those.
I put those plugins that I have to include from Eclipse in an "eclipse"
feature to separate them from the plugins that I want to include
from CSS core, CSS applications etc.
You use the IDE's "Run Configuration/Plug-Ins" tab to determine which plugins you want/need,
try that by starting the product from within the IDE,
and once you like the result, you enter those into the features which are
then used to "export" the product.
-Kay
From: Pavel Masloff <pavel.masloff@gmail.com<mailto:pavel.masloff@gmail.com>>
Date: Tue, 24 Jan 2012 16:16:31 -0500
To: Kasemir Kay <kasemirk@ornl.gov<mailto:kasemirk@ornl.gov>>
Cc: "tech-talk@aps.anl.gov<mailto:tech-talk@aps.anl.gov>" <tech-talk@aps.anl.gov<mailto:tech-talk@aps.anl.gov>>
Kay!
I have launched the original KEK 3.0.1 versions from IDE (Sync-> Launch as an Eclipse application) and epics doesn't show up in the prefs! So the original sources have this error!!!
I have tried to launch it the other way - through Run Configurations. When I click Validate plug-ins - it says that two plugins are missing (lucene,lucene.analysis). Then I add the requiered plugins. And it works - I can see EPICS in the Preferences.
The only thing I don't understand. How to make it work through features.
> When you open the META-INF/MANIFEST.MF, you'll
> see "Require-Bundle: ..." entries in there.
> Also displayed in the "Dependencies" tab
> of the editor for plugin.xml and MANIFEST.MF.
> To get a plugin into a product, all its dependencies
> need to be included as well.
I presume, you mean the Manifest.mf of org.csstudio.platform.libs.epics.ui.
I can assure you that all the required plugins are included in  css-kek.product, namely:
 org.eclipse.help, (in org.csstudio.kek.eclipse.feature)
 org.eclipse.help.appserver, (in org.csstudio.kek.eclipse.feature)
 org.eclipse.help.base, (in org.csstudio.kek.eclipse.feature)
 org.eclipse.help.ui, (in org.csstudio.kek.eclipse.feature)
 org.eclipse.help.webapp, (in org.csstudio.kek.eclipse.feature)
 org.csstudio.platform.libs.epics (in org.csstudio.kek.core.feature)
I am confused.
Pavel
On Wed, Jan 25, 2012 at 12:23 AM, Kasemir, Kay <kasemirk@ornl.gov<mailto:kasemirk@ornl.gov>> wrote:
>I checked in Help, About, Installation Details, Plug-Ins:
>org.csstudio.platform.libs.epics.ui - does NOT show up
>org.csstudio.ui.preferences - does show up
OK, so that explains why you don't have the 'EPICS'
section in the preference GUI.
So now the Q is: Why isn't it included?
>Plugin.xml looks exactly how you described!
>Silly question: how to check the dependencies?
If your product is assembled from features,
one one such feature includes some plugin like
org.csstudio.platform.libs.epics.ui,
then that plugin should be in the product.
Except if that plugin depends on other plugins,
which are missing from the product.
When you build your product directly based on a list
of plugins, without features, there's a "add dependencies"
button in the plugin editor that automatically adds
all dependencies.
When you build your product based on features, there's
no such button because the system cannot automatically determine
in which feature you would like to add the missing plugins.
Besides, the pure dependencies are not all:
Many tools depend on org.csstudio.utility.pv to get the API
for PV support. It's up to you to also include either
org.csstudio.utility.pv.epics to access EPICS PVs,
or org.csstudio.utility.simu to access simulated PVs,
or both.
So beyond the "required" plugins you may really need additional
ones to get the product to do what you want.
But back to org.csstudio.platform.libs.epics.ui not loading,
that probably means you are missing some required dependency.
When running the product from within the Eclipse IDE,
you can use the Run Configurations/Plug-Ins/Validate Plug-Ins button.
See also http://cs-studio.sourceforge.net/docbook/, chapter "Site-Specific
Products",
section "Fix Dependencies".
-Kay
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Prev: Re: Motor record support for Galil DMC-2183 Mark Clift
Next: Re: Motor record support for Galil DMC-2183 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
Next: Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
