g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: RE: Does areaDetector Prosilica driver support Manta-series camera ?
To: <rivers@cars.uchicago.edu>, <mdavidsaver@bnl.gov>, <tech-talk@aps.anl.gov>
Date: Fri, 13 Jan 2012 09:52:59 +0000
It does, but they may be presented in a different, less user friendly way, I've included screenshots of the prosilica GC series screens.
The aravis library exposes the genicam data of the camera, and my wrapper just provides a parameter for each element in this data. I use a python script at build time to parse the genicam xml and create a suitable database and edm screen with all the relevant parameters. This has the advantage that it can support new cameras very easily, but you lose any code that the manufacturer put in their SDK because they couldn't implement it in the genicam layer.
E.g. Changing the sync outputs requires you to select the sync output you would like to change before changing its level, polarity, etc.
As Michael said, it is missing code to set a camera IP address, although I have some test code that allows connection by IP address.
Tom Cobb
+44 (0)1235 778582
> -----Original Message-----
> From: Mark Rivers [mailto:rivers@cars.uchicago.edu]
> Sent: 12 January 2012 18:06
> To: 'Davidsaver, Michael'; tech-talk@aps.anl.gov; Cobb, Tom
> (DLSLtd,RAL,DIA)
> Subject: **Possible spam**RE: Does areaDetector Prosilica driver
> Hi Michael and Tom,
> Does the aravis driver provide support for all the things in the
> prosilicaMore screen (attached), i.e. trigger, sync in/out, stream
> bytes per second, communications statistics, etc.?
> Mark
> From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-
> bounces@aps.anl.gov] On Behalf Of Davidsaver, Michael
> Sent: Thursday, January 12, 2012 10:49 AM
> To: tech-talk@aps.anl.gov
> camera ?
> In case anyone is interested.  I've been using the aravis based driver
> with some prosilica GC cameras at NSLSII for several months.  It worked
> for me right out of the box.  Also, the aravis library comes with a
> nice command line tool which was useful for testing.
> The only features lacking in aravis are connection by IP address (as
> opposed to broadcast), and support for the (AVT specific) protocol
> extension to set the camera's IP address.
> Regards,
> Michael
> > bounces@aps.anl.gov] On Behalf Of tom.cobb@diamond.ac.uk
> > Sent: Thursday, January 12, 2012 8:38 AM
> > To: rivers@cars.uchicago.edu; chen.hsinwei@nsrrc.org.tw; tech-
> > talk@aps.anl.gov
> > camera ?
> > It is also supported in the generic GigE driver (aravis):
> > http://controls.diamond.ac.uk/downloads/support/aravisGigE
> > Tom
> > > bounces@aps.anl.gov] On Behalf Of Mark Rivers
> > > Sent: 12 January 2012 13:01
> > > To: Chen, Hsin-Wei; tech-talk@aps.anl.gov
> series
> > > camera ?
> > > Yes, it should work.  The Manta uses the same vendor library as the
> > > other Prosilica (AVT) GigE cameras.
> > > Mark
> > > ________________________________
> > > From: tech-talk-bounces@aps.anl.gov [tech-talk-bounces@aps.anl.gov]
> > on
> > > behalf of Chen, Hsin-Wei [chen.hsinwei@nsrrc.org.tw]
> > > Sent: Wednesday, January 11, 2012 9:17 PM
> > > Subject: Does areaDetector Prosilica driver support Manta-series
> > > camera ?
> > > Can I use prosilica driver to control manta camera?
> > > National Synchrotron Radiation Research Center Hsin-Wei Chen
> > > Email: chen.hsinwei@nsrrc.org.tw<mailto:lee.robert@nsrrc.org.tw>
> > > TEL: 886-3-5780281-7220
> > > FAX: 886-3-5783813
> > > Address: 101 Hsin-Ann Road, Hsinchu 30076, Taiwan
> > > ?家同步?射研究中心
> > > ?鑫?
> > > 30076新竹市新安路101?
> > > ?一??: 05601093
Attachment: prosilica_GC.png
Description: prosilica_GC.png
Attachment: prosilica_GC_summary.png
Description: prosilica_GC_summary.png
Re: Does areaDetector Prosilica driver support Manta-series camera ? Michael Davidsaver
Does areaDetector Prosilica driver support Manta-series camera ? Chen, Hsin-Wei
RE: Does areaDetector Prosilica driver support Manta-series camera ? Mark Rivers
RE: Does areaDetector Prosilica driver support Manta-series camera ? tom.cobb
RE: Does areaDetector Prosilica driver support Manta-series camera ? Davidsaver, Michael
Prev: RE: Reading scope waveforms with StreamDevice + asyn Mark Rivers
Next: Re: Reading scope waveforms with StreamDevice + asyn Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: RE: Does areaDetector Prosilica driver support Manta-series camera ? Mark Rivers
Next: Re: Does areaDetector Prosilica driver support Manta-series camera ? Michael Davidsaver
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
