1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: RTEMS-MVME2300
To: Qazi Zia-ul-Haque <[email protected]>
Cc: Eric Norum <[email protected]>, [email protected]
Date: Thu, 12 Jan 2012 09:36:09 -0600 (CST)
Your readline library may need ncurses.
Try commenting out the "COMMANDLINE_LIBRARY=READLINE" line
and uncommenting the "COMMANDLINE_LIBRARY=READLINE_NCURSES" line
in base/configure/CONFIG_SITE.Common.linux-x86.
Janet
----- Original Message -----
To: "Eric Norum" <[email protected]>, "Till Straumann" <[email protected]>
Cc: [email protected]
Sent: Wednesday, January 11, 2012 9:58:27 PM
Hello
I have come to the step of installing EPICS for rtems-mvme2307. However the make is going unsuccessful.
I am attaching the output of running make. I need guidance to proceed.
Regards
Zia
On Wed, Jan 4, 2012 at 11:53 AM, Eric Norum < [email protected] > wrote:
The difference is that -DMY_DO_BOOTP=rtems_bsdnet_do_bootp tells the BSP to get the board network configuration from a BOOTP/DHCP server while -DMY_DO_BOOTP=NULL tells the BSP to get the network configuration from the NVRAM.
On Jan 3, 2012, at 7:46 PM, Michael Davidsaver wrote:
> Hello Qazi,
> There is support in RTEMS for the mvme2307 which is used with epics at
> NSLS.  The epics build config used (see attached) is very similar to
> that of the mvme2100.
> The only real difference that I can see from the 2100 config is
>> #ARCH_DEP_CFLAGS += -DMY_DO_BOOTP=NULL
>> ARCH_DEP_CFLAGS += -DMY_DO_BOOTP=rtems_bsdnet_do_bootp
> I don't know what necessitated this though.
> I hope that this is helpful.
> Michael
Eric Norum
[email protected]
Re: RTEMS-MVME2300 Eric Norum
Re: RTEMS-MVME2300 Qazi Zia-ul-Haque
Prev: RE: Strategies for working with fast-changing large arrays michael.abbott
Next: Re: RTEMS-MVME2300 Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: RTEMS-MVME2300 Qazi Zia-ul-Haque
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
