1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Strategies for working with fast-changing large arrays
To: <[email protected]>
Date: Thu, 12 Jan 2012 15:03:46 +0000
After seeing the conversation about processing large arrays with pyepics, Tom Cobb pointed out to me that we have a similar problem with large arrays in cothread:  using cothread.catools.camonitor() on a 1.4MB image (running at 30 fps) only returns a fraction of the available updates when using cothread version 2-3 (or earlier).
In brief:
1. The problem arises as a consequence of using ca_pend_event() in polling mode;
2. I have a fixed version of cothread which can now receive, deliver and process all available updates (1.4MB at 30 fps) which can be downloaded from git at http://controls.diamond.ac.uk/downloads/python/cothread/ (not currently released).
I would be extremely grateful if anybody interested in using this library would take the time to test this version (commit 50e7cfc is current at time of posting this mail).
Note that there is also an incomplete work in progress python3 branch in this repository.  Any feedback would be very welcome.
1/ Using ca_pend_event()
The attached file timing.c runs CA with preemptive callbacks disabled to subscribe to the PV described above (this is a 1.4MB array updating at 30 Hz).  If run as shown it will rapidly start dropping most updates, for example:
$ ./timing
Connected: 0x9bf6e00, 6
.....tick: 5
................tick: 16
.tick: 1
.tick: 1
.tick: 1
.tick: 1
.tick: 1
..tick: 2
..tick: 2
make: *** [test] Interrupt
I imagine the problem is that the network buffers are not being cleared properly causing the server to start backing off updates.
If on the other the timeout for ca_pend_event() is increased to say 1e-3 then most updates are delivered (though there are occasional bursts of dropouts).  If ca_context_create() is called to enable preemptive callbacks then update dropping goes away.
2/ Implications for cothread
Cothread's core CA dispatch loop calls ca_pend_event(1e-9) so it is affected by this issue; I'm surprised this hasn't been noticed before.  In the current git repository at http://controls.diamond.ac.uk/downloads/python/cothread/cothread.git linked from http://controls.diamond.ac.uk/downloads/python/cothread/ I have a fix to this issue which works by enabling preemptive callbacks (and coping with the consequences).
Note that this version of cothread continues to hide all threading issues from users of the library and that user's code will never be called preemtively.
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <time.h>
#include <cadef.h>
static chid channel_id;
static evid event_id;
static int updates = 0;
static int64_t start;
static int last_updates = 0;
static int64_t get_time(void)
    struct timespec now;
    clock_gettime(CLOCK_REALTIME, &now);
    return (int64_t) now.tv_sec * 1000000 + now.tv_nsec / 1000;
static void on_connect(struct connection_handler_args args)
    printf("Connected: %p, %ld\n", args.chid, args.op);
static void on_update(struct event_handler_args args)
    printf(".");
    fflush(stdout);
    updates += 1;
    int64_t now = get_time();
    if (now - start >= 1000000)
        printf("tick: %d\n", updates - last_updates);
        last_updates = updates;
        start = now;
int main(int argc, const char **argv)
    int count = 0;
    if (argc > 1)
        count = atoi(argv[1]);
    ca_context_create(ca_disable_preemptive_callback);
    ca_create_channel(
        "ARAVISCAM1:ARR:ArrayData", on_connect, NULL, 0, &channel_id);
    ca_create_subscription(
        DBR_CHAR, count, channel_id, DBE_VALUE, on_update, NULL, &event_id);
    start = get_time();
    while (true)
        ca_pend_event(1e-9);
        usleep(10000);
    return 0;
Re: Strategies for working with fast-changing large arrays Matt Newville
Re: pyepics: Strategies for working with fast-changing large arrays Anton Derbenev
Re: pyepics: Strategies for working with fast-changing large arrays Andrew Johnson
Prev: Re: StripTool equivalent in Qt? Mark Davis
Next: Re: RTEMS-MVME2300 Janet Anderson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: pyepics: Strategies for working with fast-changing large arrays Matt Newville
Next: Re: Strategies for working with fast-changing large arrays Matt Newville
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
