1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Writing long strings PV in BOY
To: [email protected]
Date: Wed, 23 Nov 2011 11:07:45 -0600
Juan,
The only widgets that deal directly with waveform of chars as a long string are the text entry/update. The reason that your code is not working is that setValue checks type and the type created by createIntArray (int[]) is not one of the recognized types. Integer [] is supported so if you can create this ( I'm just not that fluent in Javascript ) then I think that you can do what you want.
I have done a test edit of the code and have come up with the following patch that will allow passing int[] to the setValue so that your original script should work, although I had trouble since you created an array of 10 elements but had a longer string. This section of code is not mine so I am going to pass this off to others in the group to accept & commit. This will not fix your immediate issue but should make it possible to do this in the future.
John Hammonds
diff -r a6e2537a9c5c core/plugins/org.csstudio.utility.pv.epics/src/org/csstudio/utility/pv/epics/EPICS_V3_PV.java --- a/core/plugins/org.csstudio.utility.pv.epics/src/org/csstudio/utility/pv/epics/EPICS_V3_PV.java Thu Oct 27 13:54:01 2011 -0500 +++ b/core/plugins/org.csstudio.utility.pv.epics/src/org/csstudio/utility/pv/epics/EPICS_V3_PV.java Wed Nov 23 10:58:49 2011 -0600
@@ -495,7 +495,7 @@
                 final int val = ((Integer)new_value).intValue();
                 channel_ref.getChannel().put(val);
-            else if (new_value instanceof Integer [])
+            else if (new_value instanceof Integer [] )
                 final Integer ival[] = (Integer [])new_value;
                 final int val[] = new int[ival.length];
@@ -503,8 +503,12 @@
                     val[i] = ival[i].intValue();
+            else if (new_value instanceof int[])
+                channel_ref.getChannel().put((int[])new_value);
             } else {
-                throw new Exception("Cannot handle type "
+                throw new Exception("Cannot handle data type "
                                     + new_value.getClass().getName());
On 11/23/2011 7:27 AM, [email protected] wrote:
I have a waveform record setup as array of char (to support long string) and I'm trying to write a string to it via BOY Action button. I setup a "Write PV" action in the widget but the string does not get written, so perhaps long strings are not supported in BOY actions (it works for Text Inputs).
I tried a Javascript code to convert the string to an array of char via the following code:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
var strArray = DataUtil.createIntArray(10);
var pv = widget.getPV();
var strText = "this is a test";
for(var i=0; i<strText.length; i++) {
   strArray[i] = strText.charCodeAt(i);
pv.setValue(strArray);
but the script throws an exception in BOY's console "Wrapped java.lang.Exception: Cannot handle type [I".
Is there any way in BOY to write a string to a waveform record as an array of char (support long strings)? I'm using SNS CSS 3.0.2 (Basic) for MacOSX.
Thanks in advance,
   Juan.
Juan Carlos Guzman
Software Engineer
Australia Telescope National Facility
CSIRO Astronomy and Space Science
P.O.Box 76, Epping NSW 1710, Australia
Phone: +61 2 9372 4457
Fax: +61 2 9372 4310
Email: [email protected]<mailto:[email protected]>
John Hammonds
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
(630)252-5317
RE: Writing long strings PV in BOY Chen, Xihui
Writing long strings PV in BOY Juan.Guzman
Prev: Writing long strings PV in BOY Juan.Guzman
Next: Re: Gateway binary distribution available for RedHat 5.5 Martin Konrad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Writing long strings PV in BOY Chen, Xihui
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
