Hi Emmanuel,
> I would like to install EPICS gateway and I’m wondering if I can find
> the binary distribution? Does anyone has RPM packages or binary files
> availalbe?
It's easy to generate them if you use CMake to build cagateway. Some
weeks ago I posted the necessary rules for CMake
(http://www.aps.anl.gov/epics/tech-talk/2011/msg01717.php) but it seems
they did not made it into the tarball yet.
@Ralph: What's the status with that?
Simply give it a try (copy the files into the top directory of gateway
and follow the rules in README.CMake). I'm very interested in people
testing this stuff ;-)
Cheers
Martin
P.S.: I attached the files again because the list archive seems to drop
the filenames and prints everything without any spacing between the
files. In addition to that a small bug has been fixed since then...
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
# Martin Konrad <[email protected]>
# License: GPLv2/v3
# Try to find libpcre (Perl Compatible Regular Expressions)
# Once done this will define
# PCRE_FOUND - system has libpcre
# PCRE_INCLUDE_DIR - the libpcre include directory
# PCRE_LIBRARY - where to find libpcre
# PCRE_LIBRARIES - Link these to use libpcre
if(PCRE_INCLUDE_DIR AND PCRE_LIBRARIES)
# in cache already
set(PCRE_FOUND TRUE)
else(PCRE_INCLUDE_DIR AND PCRE_LIBRARIES)
if(NOT WIN32)
# use pkg-config to get the directories and then use these values
# in the FIND_PATH() and FIND_LIBRARY() calls
find_package(PkgConfig)
pkg_check_modules(PC_PCRE libpcre)
endif(NOT WIN32)
find_path(PCRE_INCLUDE_DIR
NAMES
pcre.h
HINTS
${PCRE_PKG_INCLUDE_DIRS}
PATHS
/usr/include
/usr/local/include
find_library(PCRE_LIBRARY
NAMES
pcre
HINTS
${PCRE_PKG_LIBRARY_DIRS}
PATHS
/usr/lib
/usr/local/lib
set(PCRE_LIBRARIES ${PCRE_LIBRARY})
# handle the QUIETLY AND REQUIRED arguments AND set PCRE_FOUND to TRUE if
# all listed variables are TRUE
# include(${CMAKE_CURRENT_LIST_DIR}/FindPackageHandleStandardArgs.cmake)
include(FindPackageHandleStandardArgs)
find_package_handle_standard_args(PCRE DEFAULT_MSG PCRE_LIBRARY PCRE_INCLUDE_DIR)
mark_as_advanced(PCRE_INCLUDE_DIR PCRE_LIBRARY)
endif(PCRE_INCLUDE_DIR AND PCRE_LIBRARIES)
cmake_minimum_required(VERSION 2.8 FATAL_ERROR)
project(epics-cagateway)
set(VERSION_MAJOR 2)
set(VERSION_MINOR 0)
set(VERSION_MAINTENANCE 4)
set(VERSION_BUILD 0)
set(VERSION_STRING "${VERSION_MAJOR}.${VERSION_MINOR}.${VERSION_MAINTENANCE}.${VERSION_BUILD}")
set(gateway_SRCS
gateway.cc
gateAsCa.cc
gateAs.cc
gateAsyncIO.cc
gatePv.cc
gateResources.cc
gateServer.cc
gateStat.cc
gateVc.cc
set(CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}")
find_package(EPICS REQUIRED ca cas asHost gdd Com)
include_directories(${EPICS_INCLUDE_DIRS})
set(CMAKE_CXX_FLAGS "-Dlinux -O3 -Wall")
option(NODEBUG "Turn off Gateway debug calls" OFF)
if(NODEBUG)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DNODEBUG")
endif(NODEBUG)
option(STAT_PVS "Use status PVs" ON)
if(STAT_PVS)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DSTAT_PVS")
endif(STAT_PVS)
option(RATE_STATS "Use rate statistics" ON)
if(RATE_STATS)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DRATE_STATS")
endif(RATE_STATS)
option(CONTROL_PVS "Use control PV's" ON)
if(CONTROL_PVS)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DCONTROL_PVS")
endif(CONTROL_PVS)
option(HEARTBEAT_PV "Use heartbeat PV" OFF)
if(HEARTBEAT_PV)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DHEARTBEAT_PV")
endif(HEARTBEAT_PV)
option(CAS_DIAGNOSTICS "Use CAS diagnostics statistics" ON)
if(CAS_DIAGNOSTICS)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DCAS_DIAGNOSTICS")
endif(CAS_DIAGNOSTICS)
option(HANDLE_EXCEPTIONS "Install exception handler and print exceptions to log file" ON)
if(CAS_DIAGNOSTICS)
option(USE_DENYFROM "Use deny from" YES)
if(USE_DENYFROM)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DUSE_DENYFROM")
endif(USE_DENYFROM)
option(USE_NEG_REGEXP "Use neg regexp" ON)
if(USE_NEG_REGEXP)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DUSE_NEG_REGEXP")
endif(USE_NEG_REGEXP)
option(USE_PCRE "Use Perl compatible regular expressions" OFF)
if(USE_PCRE)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DUSE_PCRE")
find_package(PCRE REQUIRED)
endif(USE_PCRE)
add_executable(gateway ${gateway_SRCS})
target_link_libraries(gateway ${EPICS_Com_LIBRARY} ${EPICS_HOST_LIBRARIES} ${EPICS_ca_LIBRARY} ${EPICS_asHost_LIBRARY} ${EPICS_cas_LIBRARY} ${EPICS_gdd_LIBRARY} ${PCRE_LIBRARIES})
# Package information
set(CPACK_PACKAGE_VERSION ${VERSION_STRING})
set(CPACK_PACKAGE_CONTACT "Martin Konrad <[email protected]>")
set(CPACK_PACKAGE_DESCRIPTION "Channel access gateway for EPICS\n The Experimental Physics and Industrial Control System is a collection of tools, libraries and applications for creating a distributed soft real-time control system.\n .\n This package provides the EPICS channel access gateway. It acts as a kind of proxy for channel access and therefore allows clients to access IOCs in other subnets. In addition to that it provides channel access security.")
set(CPACK_DEBIAN_PACKAGE_HOMEPAGE "http://www.aps.anl.gov/epics/extensions/gateway/")
set(CPACK_DEBIAN_PACKAGE_DESCRIPTION ${CPACK_PACKAGE_DESCRIPTION})
set(CPACK_DEBIAN_PACKAGE_DEPENDS "libepics3.14.11 (>=3.14.11)")
if(USE_PCRE)
set(CPACK_DEBIAN_PACKAGE_DEPENDS "${CPACK_DEBIAN_PACKAGE_DEPENDS}, libpcre3")
endif(USE_PCRE)
# Package settings
if(${UNIX})
set(CPACK_GENERATOR "DEB;RPM")
set(CPACK_CMAKE_GENERATOR "Unix Makefiles")
set(CPACK_PACKAGE_NAME ${PROJECT_NAME})
set(CPACK_PACKAGE_FILE_NAME ${PROJECT_NAME}-${VERSION_STRING}${PACK_ARCH})
endif(${UNIX})
install(TARGETS gateway DESTINATION bin)
install(DIRECTORY docs/ DESTINATION share/doc/${PROJECT_NAME} PATTERN ".svn" EXCLUDE)
include(CPack) # Find EPICS
# Use as:
# FIND_PACKAGE(EPICS REQUIRED)
# To use a local version first set:
# SET(CMAKE_MODULE_PATH "/somedir/epics/cmake")
# Creates variables:
# EPICS_BASE - Location
# EPICS_FOUND - Where all components found?
# EPICS_INCLUDE_DIRS - CPP search path (global and OS)
# EPICS_Com_LIBRARIES - libCom and dependencies
# EPICS_*_LIBRARY - Individual libs w/o dependencies
# EPICS_HOST_LIBRARIES - All *Host libraries and cas/gdd
# EPICS_IOC_LIBRARIES - All *Ioc libraries
# EPICS_INCLUDE_DIR
# EPICS_OS_INCLUDE_DIR
# EPICS OS classes
# AIX cygwin32 Darwin freebsd
# hpux interix Linux osf RTEMS
# solaris vxWorks WIN32
set(_EPICS_ALL_LIBS
cas gdd asHost dbStaticHost registryIoc
recIoc softDevIoc miscIoc rsrvIoc dbtoolsIoc asIoc
dbIoc registryIoc dbStaticIoc ca Com
find_package(EPICSArch)
find_path(EPICS_BASE
NAMES include/epicsVersion.h
dbd/base.dbd
PATHS /usr/lib/epics
/opt/epics/current
DOC "Location of EPICS Base"
if(NOT EPICS_BASE)
if(EPICS_FIND_REQUIRED)
message(FATAL_ERROR "Failed to find EPICS Base location")
endif(EPICS_FIND_REQUIRED)
endif(NOT EPICS_BASE)
find_path(EPICS_INCLUDE_DIR epicsVersion.h
PATHS ${EPICS_BASE}/include
DOC "EPICS include dir"
NO_DEFAULT_PATH
if(EPICS_INCLUDE_DIR)
find_path(EPICS_OS_INCLUDE_DIR
NAMES epicsMath.h osdTime.h osiUnistd.h
PATHS ${EPICS_INCLUDE_DIR}/os/
PATH_SUFFIXES ${OS_CLASS}
DOC "EPICS OSD include dir"
NO_DEFAULT_PATH
if(EPICS_OS_INCLUDE_DIR)
SET(EPICS_INCLUDE_DIRS
${EPICS_OS_INCLUDE_DIR}
endif(EPICS_OS_INCLUDE_DIR)
endif(EPICS_INCLUDE_DIR)
if(EPICS_INCLUDE_DIR AND EPICS_OS_INCLUDE_DIR)
foreach(COMP ${_EPICS_ALL_LIBS})
find_library(EPICS_${COMP}_LIBRARY ${COMP}
PATHS ${EPICS_BASE}/lib
PATH_SUFFIXES ${T_A}
NO_DEFAULT_PATH
DOC "Location of the EPICS ${COMP} library"
endforeach(COMP)
endif(EPICS_INCLUDE_DIR AND EPICS_OS_INCLUDE_DIR)
# Ensure all components are present if needed
# When find_package() is invoked with REQUIRED
# ensure that all of the following are set
find_package_handle_standard_args(EPICS DEFAULT_MSG
EPICS_BASE
EPICS_INCLUDE_DIR EPICS_OS_INCLUDE_DIR
EPICS_Com_LIBRARY
EPICS_ca_LIBRARY
EPICS_cas_LIBRARY
EPICS_gdd_LIBRARY
EPICS_dbStaticHost_LIBRARY
EPICS_registryIoc_LIBRARY
EPICS_recIoc_LIBRARY
EPICS_softDevIoc_LIBRARY
EPICS_miscIoc_LIBRARY
EPICS_rsrvIoc_LIBRARY
EPICS_dbtoolsIoc_LIBRARY
EPICS_asIoc_LIBRARY
EPICS_dbIoc_LIBRARY
EPICS_dbStaticIoc_LIBRARY
set(EPICS_Com_LIBRARIES ${EPICS_Com_LIBRARY})
#TODO: error checking below
if(NOT RTEMS)
find_package(Threads REQUIRED)
list(APPEND EPICS_Com_LIBRARIES ${CMAKE_THREAD_LIBS_INIT})
endif(NOT RTEMS)
if(UNIX AND NOT RTEMS)
find_library(LIBRT rt)
find_library(LIBDL dl)
list(APPEND EPICS_Com_LIBRARIES ${LIBRT} ${LIBDL})
endif(UNIX AND NOT RTEMS)
if(RTEMS)
find_library(RTEMSCPU rtemscpu)
find_library(RTEMSNFS nfs)
list(APPEND EPICS_Com_LIBRARIES ${RTEMSCPU} ${RTEMSNFS})
if(RTEMS_NEED_BSPEXT)
find_library(BSPEXT bspExt)
list(APPEND EPICS_Com_LIBRARIES ${BSPEXT})
endif(RTEMS_NEED_BSPEXT)
endif(RTEMS)
# Libraries needed to build an IOC
set(EPICS_BASE_IOC_LIBS
${EPICS_recIoc_LIBRARY}
${EPICS_softDevIoc_LIBRARY}
${EPICS_miscIoc_LIBRARY}
${EPICS_rsrvIoc_LIBRARY}
${EPICS_dbtoolsIoc_LIBRARY}
${EPICS_asIoc_LIBRARY}
${EPICS_dbIoc_LIBRARY}
${EPICS_registryIoc_LIBRARY}
${EPICS_dbStaticIoc_LIBRARY}
${EPICS_ca_LIBRARY}
${EPICS_Com_LIBRARIES}
set(EPICS_INSTALL_BIN "bin/${T_A}" CACHE FILEPATH "Location for installed binaries")
set(EPICS_INSTALL_LIB "lib/${T_A}" CACHE FILEPATH "Location for all libraries")
set(EPICS_INSTALL_INCLUDE "include" CACHE FILEPATH "Location for C/C++ headers")
set(EPICS_INSTALL_INCLUDE_OS "include/os/${OS_CLASS}" CACHE FILEPATH "Location for OSD C/C++ Headers")
set(EPICS_INSTALL_DBD "dbd" CACHE FILEPATH "Location for EPICS DBD files")
set(EPICS_INSTALL_DB "db" CACHE FILEPATH "Location for EPICS DB files")
mark_as_advanced(
EPICS_BIN_DIR EPICS_LIB_DIR
EPICS_DBD_DIR EPICS_DB_DIR
EPICS_CMAKE_DIR
# Determine EPICS Arch and OS Class
# Use as:
# find_package(EPICSArch)
# T_A - Target Archetecture
# OS_CLASS - Primary (first) OSI system class
# OS_CLASSES - List of all OSI classes
# IOC - True if target can build IOC things
# HOST - True if target can build Host things
include(FindPackageMessage)
if(UNIX)
if(CMAKE_SYSTEM_NAME MATCHES Linux)
set(HOST 1)
set(IOC 1)
set(OS_CLASS Linux)
set(OS_CLASSES Linux posix default)
if(CMAKE_SYSTEM_PROCESSOR MATCHES "^i.86$")
set(T_A "linux-x86")
elseif(CMAKE_SYSTEM_PROCESSOR MATCHES "^x86_64$")
set(T_A "linux-x86_64")
elseif(CMAKE_SYSTEM_PROCESSOR MATCHES "^powerpc")
set(T_A "linux-ppc")
else(CMAKE_SYSTEM_PROCESSOR MATCHES "^i.86$")
message(FATAL_ERROR "Unknown Linux Variant: ${CMAKE_SYSTEM_PROCESSOR}")
endif(CMAKE_SYSTEM_PROCESSOR MATCHES "^i.86$")
elseif(RTEMS)
set(HOST 0)
set(IOC 1)
set(OS_CLASS RTEMS)
set(OS_CLASSES RTEMS posix default)
set(T_A "RTEMS-${RTEMS_BSP}")
else(CMAKE_SYSTEM_NAME MATCHES Linux)
message(FATAL_ERROR "Unknown *nix Variant: ${CMAKE_SYSTEM_NAME}")
endif(CMAKE_SYSTEM_NAME MATCHES Linux)
elseif(WIN32)
set(HOST 1)
set(IOC 1)
set(OS_CLASS WIN32)
set(OS_CLASSES WIN32 default)
if(MINGW)
set(T_A "win32-x86-mingw")
elseif(CYGWIN)
set(T_A "win32-x86-cygwin")
elseif(MSVC)
set(T_A "win32-x86")
elseif(BORLAND)
set(T_A "win32-x86-borland")
else(MINGW)
message(FATAL_ERROR "Unknown Windows variant")
endif(MINGW)
else(UNIX)
message(FATAL_ERROR "Unable to determine EPICS OS class")
endif(UNIX)
if(CMAKE_BUILD_TYPE STREQUAL "Debug")
set(T_A "${T_A}-debug")
endif(CMAKE_BUILD_TYPE STREQUAL "Debug")
find_package_message(EPICSArch
"EPICS Target: ${T_A} (${OS_CLASS})"
"[${T_A}][${OS_CLASS}]"
- Re: Gateway patches (CMake) Ralph Lange
- Gateway binary distribution available for RedHat 5.5 ZYCHLA Emmanuel
Re: Writing long strings PV in BOY John Hammonds
RE: Writing long strings PV in BOY Chen, Xihui
<2011>
<2011>
