Hi Mark,
I am running a test soft IOC which reads from a handful of Beckhoff modules. Just recently it started to crash with segmentation fault. Here is some of the gdb output looking at the core dump file:
Loaded symbols for /lib/libnss_files.so.2
Core was generated by `../../bin/linux-x86/bkh ./st.cmd'.
Program terminated with signal 11, Segmentation fault.
#0 0x00d5e9bd in writeRead (pasynUser=0x9095664, write_buffer=0x9094dd0 "",
write_buffer_len=6, read_buffer=0x9095028 "\003 ", read_buffer_len=8,
timeout=2, nbytesOut=0xb7e091c8, nbytesIn=0xb7e091c4, eomReason=0xb7e091c0)
at ../../asyn/interfaces/asynOctetSyncIO.c:265
265 status = pioPvt->pasynOctet->flush(pioPvt->octetPvt,pasynUser);
(gdb) bt
#1 0x008a4834 in doModbusIO (pPlc=0x9094ca0, slave=0, function=3, start=4106,
data="" len=3) at ../drvModbusAsyn.c:1439
#2 0x008a33eb in readPoller (pPlc=0x9094ca0) at ../drvModbusAsyn.c:1087
#3 0x00178244 in start_routine (arg=0x9095fb0)
at ../../../src/libCom/osi/os/posix/osdThread.c:282
#4 0x00c59832 in start_thread () from /lib/libpthread.so.0
#5 0x0075546e in clone () from /lib/libc.so.6
(gdb)
Before the crash this was printed in the console:
epics> 2011/11/09 05:34:58.852 drvModbusAsyn::doModbusIO port BKH3_3408 error calling writeRead, error=192.168.0.193:502 timeout: Resource temporarily unavailable, nwrite=6/6, nread=0
Segmentation fault (core dumped)
I think that this started when I connected a prosilica camera to the same network hub, a private subnet (192.168.0.x).
The camera is running continuously sending image data at 10 frames/s.
At this point I am not sure, how long it runs before crash.
I will let you know if I discover anything new.
Zen
