FYI - I finally got around to doing this and found (for my installation
of mingw-get, version 0.4-alpha-1) I had to execute the command as follows:
"mingw-get install msys-patch"
Thanks Andrew
On 11/11/11 11:06 AM, Andrew Johnson wrote:
Hi Josh,
On 2011-11-11 Josh Stein wrote:
Has anyone found an unbundled Patch tool which works properly for Windows?
Since I happen to know that you have a recent version of MinGW installed, I
think you should just be able to use the command "mingw-get install patch" to
install the MSYS version of patch, which I believe will be put into
C:/MinGW/msys/1.0/bin (the number might be different). It may also add one or
two more things but that's all I had to do yesterday to be able to apply a
Unix patch file on my XP system.
- Andrew
- 'Patch' tool for windows Josh Stein
- Re: 'Patch' tool for windows Andrew Johnson
RE: recommendations for win64 build graham.cox
Re: documentation for stringout fields Andrew Johnson
<2011>
Modbus - Beckhoff Szalata, Zenon M.
<2011>
