----- Original Message -----
To: "Paul Nord" <[email protected]>
Sent: Wednesday, September 28, 2011 7:19 AM
Subject: Re: Simple ADC - Ethernet device?
For this sort of thing we tend to use Rabbit-based hardware (part of Digi)
like this:
http://www.digi.com/products/wireless-wired-embedded-solutions/single-board-computers/bl2100#models
The software for these was developed in-house (by me) running on top of a
small UNIX-like RTOS (also written by me when I got fed up with the
vendor's offerings :-).
Details of the OS can be found here:
http://groups.nscl.msu.edu/controls/
I am also putting the finishing touches on a paper and poster presentation
for the upcoming ICALEPCS conference and I will add those to the above
page soon.
We currently have hundreds of Rabbit modules running various controllers
in the lab, many of which contain the Rabbit BL2105 Single Board Computer
which has 11 12-bit ADC inputs and 4 12-bit DAC outputs. NOTE: The
BL2105 is not actually listed on the Digi web site at this time but can
still be purchased - the model # is important as the BL2105 contains 512K
of RAM and 512K flash.
We also have several in-house designs that use the faster Rabbit Core
Module RCM3200 and incorporate various numbers of 16-bit ADCs and DACs and
digital I/O (mostly for controlling power supplies and motors).
Communication with all of these is over Ethernet and at present uses an
Open-Modbus/TCP driver (also written in house - for some reason not
currently listed on our public-access website, which it probably should
be). There is also a (not quite finished) EPICS CA server for DEBROS, but
I don't have any time frame for when it will be completed (probably not
until higher priority stuff is addressed).
We have provided code and specs on our in-house designs to other labs in
the past, so if you are interested any of that should be available as
well. But if all you want is to monitor and/or control a handful of
inputs and outputs (analog and/or digital), the BL2105 running DEBROS is
probably the simplest of these options.
Mark Davis
NSCL
To: <[email protected]>
Sent: Tuesday, September 27, 2011 10:38 AM
Subject: Simple ADC - Ethernet device?
I need to monitor the pressure in a gas supply bottle. We expect to need
to change gas bottles every few days and we'd like to alert the detector
operators in plenty of time.
Getting a transducer to produce a voltage is simple enough. I'm a little
unclear about the next step: digitizing that voltage and getting that
information to our EPICS softIOC. I'd like a simple box that connects to
the voltage and also to an ethernet port.
There is an Epics driver for the environment monitor Websensor from
Esensors Inc. It monitors temperature, humidity, and illumination. The
device can also monitor a voltage reading. I presume it would be easy
modify the driver to also get the voltage reading.
Is there another ethernet-based ADC that you would recommend?
There are some nice USB devices. But I don't really want to setup a
computer just to monitor one voltage remotely.
I found some nice modular systems from Omega and NI. Alas, there are no
Epics drivers.
Paul
RE: [S7plc EPICS driver] REAL type record jumps to zero Di Maio Franck
Re: Transform Record no_inlink test Bruce Hill
<2011>
RE: Simple ADC - Ethernet device? Szalata, Zenon M.
Xerces Re: problem running Channel Archiver on 64-bit Scientific Linux 6 Kasemir, Kay
<2011>
