At SLAC we use Beckhoff Field Bus devices. A typical set would consist of BK9000, KL3102, and KL9010.
BK9000 is the Ethernet coupler, KL3102 is a two channel differential input analog module (-10V to +10V), and KL9010 is a terminator. These are not expensive. The BK9000 uses Modbus protocol. Beckhoff has a large array of Field Bus products.
I am using Modbus driver written by Mark Rivers. A soft IOC consists of the afore mentioned driver, a handful of EPICS records, and configuration specified in the st.cmd file.
Zen
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Paul Nord
> Sent: Tuesday, September 27, 2011 7:38 AM
> To: [email protected]
> Subject: Simple ADC - Ethernet device?
> I need to monitor the pressure in a gas supply bottle. We expect to need to
> change gas bottles every few days and we'd like to alert the detector operators
> in plenty of time.
> Getting a transducer to produce a voltage is simple enough. I'm a little unclear
> about the next step: digitizing that voltage and getting that information to our
> EPICS softIOC. I'd like a simple box that connects to the voltage and also to an
> ethernet port.
> There is an Epics driver for the environment monitor Websensor from
> Esensors Inc. It monitors temperature, humidity, and illumination. The device
> can also monitor a voltage reading. I presume it would be easy modify the
> driver to also get the voltage reading.
> Is there another ethernet-based ADC that you would recommend?
> There are some nice USB devices. But I don't really want to setup a computer
> just to monitor one voltage remotely.
> I found some nice modular systems from Omega and NI. Alas, there are no
> Epics drivers.
> Paul
- Simple ADC - Ethernet device? Paul Nord
Re: Simple ADC - Ethernet device? Dave Reid
Re: Simple ADC - Ethernet device? Paul Nord
<2011>
Fw: Simple ADC - Ethernet device? Mark Davis
<2011>
