1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS support for Delta Tau UMAC system
To: [email protected]
Cc: [email protected]
Date: Fri, 15 Jul 2011 12:09:31 -0500
Matthew,
Is the call to pmacAsynIPPortConfigure() that is mentioned in this older tech-talk message no longer needed in the latest version of tpmac?:
http://www.aps.anl.gov/epics/tech-talk/2009/msg00062.php
Kevin
On 5/16/11 12:49 PM, [email protected] wrote:
Hi Zhan,
The tpmac support module has support for ethernet PMACs. There is an Asyn interpose layer that deals with the additional protocol that the ethernet PMACs need.
In your IOC startup file, you'll need something like this:
#Asyn PORT name, #IP address and IP port
pmacAsynIPConfigure("pmacLV", "172.23.243.156:1025")
#Asyn PORT name, #Asyn ADDR, #Card ID, #Number of axes
pmacAsynMotorCreate("pmacLV", 0, 0, 8)
#Asyn PORT name for motor record, #Asyn motor driver name, #Card ID, #Number of axes+1
drvAsynMotorConfigure("PMAC1", "pmacAsynMotor", 0, 9)
Hope this helps.
Cheers,
Matthew
-----Original Message-----
[email protected]] On Behalf Of Zhan Zhang
Sent: 16 May 2011 17:59
Subject: EPICS support for Delta Tau UMAC system
Hi folks,
	I wonder if anyone has developed EPICS support for the Delta Tau
UMAC system.  This is a 3-U rack-mount system with power supply,
drivers,
controllers, and communication board (a turbo PMAC2 board), which
communicates with the host PC via USB or Ethernet (or serial).  My
communication/CPU board has a SN # 3X0-603766 and unfortunately, I
could not
find the product on the Delta Tau webpage.
	A simple search on this list suggests there were enough work done
on
the PMAC-VME controller.  But I don't see any related to the UMAC
system I
have.  Anyone has any information?  Thanks a lot!
Zhan
Zhan Zhang, Ph. D.
Argonne National Laboratory
X-ray Science Division, 438-D005
9700 S. Cass Ave.
Argonne, IL 60439
Tel : 630-252-0863
Email: [email protected]
Handling failures in st.cmd Zelazny, Michael Stanley
Re: Handling failures in st.cmd Ernest L. Williams Jr.
Re: Handling failures in st.cmd Benjamin Franksen
EPICS support for Delta Tau UMAC system Zhan Zhang
RE: EPICS support for Delta Tau UMAC system matthew.pearson
Prev: Announce: sequencer release 2.1.0 Benjamin Franksen
Next: RE: streamdevice + asyn stuck Zhang, Dehong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EPICS support for Delta Tau UMAC system Zhan Zhang
Next: Re: Handling failures in st.cmd Till Straumann
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
