Am Freitag, 24. Juni 2011, um 23:43:33 schrieben Sie:
> On 6/24/11 4:05 PM, Benjamin Franksen wrote:
> > This seems to be the only test that failed.
> > The tests in this group check that the (SNL+C) compilers reject certain
> > constructs; I have made these tests more strict by counting how often the
> > word 'error' appears in the output. Depending on the C compiler this
> > number varies, so I have to adapt the range of permissible occurrences
> > for every new compiler tested. Could you remove the comment marker from
> > line 43 of
> > test/compiler/test.plt, repeat 'make runtests' inside test/compiler, and
> > send me the output?
> Hi, Ben.
> The output is attached.
> In case it's helpful, my GCC version is 4.2.1.
> (On a side note, my system also has an LLVM compiler toolchain
> which Apple seems to be behind. Maybe at some point the default
> compiler on Mac OS X for the EPICS build system will become
> this, in which case perhaps the "error" word counting will need
> to change again.)
The failing test is the tooLong test which checks that assign on 64 bit types
gets rejected. The compiler output is:
../tooLong.st:15:2: error: #error variable 'long l' cannot be assigned to a PV
(on the chosen target system) because Channel Access does not support integral
types longer than 4 bytes. You can use 'int' instead, or the fixed size type
'int32_t'.
# ../tooLong.st:18:2: error: #error variable 'unsigned long ul' cannot be
assigned to a PV (on the chosen target system) because Channel Access does not
support integral types longer than 4 bytes. You can use 'unsigned int'
instead, or the fixed size type 'uint32_t'.
This is correct; the problem is that the perl script thinks the test should
succeed, not fail, since the EPICS_HOST_ARCH does not match against the string
'64'. So, I rather have to adapt the expectation and refine the heuristic that
tries to determine 64-bit-ness of the host arch. What is the value of
EPICS_HOST_ARCH for your system?
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: Sequencer news: latest snapshot Andrew Johnson
- Re: Sequencer news: latest snapshot J. Lewis Muir
- Sequencer news: latest snapshot Benjamin Franksen
- Re: Sequencer news: latest snapshot Benjamin Franksen
Re: Sequencer news: latest snapshot Tim Mooney
<2011>
<2011>
