On 6/24/11 4:05 PM, Benjamin Franksen wrote:
> This seems to be the only test that failed.
> The tests in this group check that the (SNL+C) compilers reject certain
> constructs; I have made these tests more strict by counting how often the word
> 'error' appears in the output. Depending on the C compiler this number varies,
> so I have to adapt the range of permissible occurrences for every new compiler
> tested. Could you remove the comment marker from line 43 of
> test/compiler/test.plt, repeat 'make runtests' inside test/compiler, and send
> me the output?
Hi, Ben.
The output is attached.
In case it's helpful, my GCC version is 4.2.1.
(On a side note, my system also has an LLVM compiler toolchain
which Apple seems to be behind. Maybe at some point the default
compiler on Mac OS X for the EPICS build system will become
this, in which case perhaps the "error" word counting will need
to change again.)
Lewis
$ make -s runtests
test.t .. # sncExOpt_DuplOpt result=0, response=
test.t .. 1/15 # tooLong result=512, response=../tooLong.st:15:2: error: #error variable 'long l' cannot be assigned to a PV (on the chosen target system) because Channel Access does not support integral types longer than 4 bytes. You can use 'int' instead, or the fixed size type 'int32_t'.
# ../tooLong.st:18:2: error: #error variable 'unsigned long ul' cannot be assigned to a PV (on the chosen target system) because Channel Access does not support integral types longer than 4 bytes. You can use 'unsigned int' instead, or the fixed size type 'uint32_t'.
# make[3]: *** [tooLong.o] Error 1
# make[2]: *** [all] Error 2
# Failed test at test.t line 47.
# sncExOpt_UnrecOpt result=0, response=../sncExOpt_UnrecOpt.st:8: warning: unknown state option 'c'
test.t .. 3/15 # syncq_no_size result=0, response=:6: warning: leaving out the queue size is deprecated, queue size defaults to 100 elements
test.t .. 4/15 # efArray result=512, response=../simple.st:3: error: cannot declare array of event flags
# make[3]: *** [efArray.c] Error 1
# efGlobal result=512, response=../efGlobal.st:4: error: event flags can only be declared at the top-level
# ../efGlobal.st:6: error: event flags can only be declared at the top-level
# ../efGlobal.st:8: error: event flags can only be declared at the top-level
# make[3]: *** [efGlobal.c] Error 1
# efPointer result=512, response=../simple.st:3: error: cannot declare pointer to event flag
# make[3]: *** [efPointer.c] Error 1
test.t .. 7/15 # foreignGlobal result=512, response=../foreignGlobal.st:4: error: foreign variables can only be declared at the top-level
# ../foreignGlobal.st:6: error: foreign variables can only be declared at the top-level
# ../foreignGlobal.st:8: error: foreign variables can only be declared at the top-level
# make[3]: *** [foreignGlobal.c] Error 1
# misplacedExit result=512, response=../misplacedExit.st:9: syntax error near token 'when'
# ../misplacedExit.st:11: syntax error near token '}'
# parser giving up
# make[3]: *** [misplacedExit.c] Error 1
test.t .. 9/15 # pvNotAssigned result=512, response=../pvNotAssigned.st:6: error: parameter 1 to 'pvGet' was not assigned to a pv
# ../pvNotAssigned.st:7: error: parameter 1 to 'pvPut' was not assigned to a pv
# ../pvNotAssigned.st:8: error: parameter 1 to 'pvAssign' was not assigned to a pv
# ../pvNotAssigned.st:9: error: parameter 1 to 'pvMonitor' was not assigned to a pv
# ../pvNotAssigned.st:14: error: parameter 1 to 'pvAssign' was not assigned to a pv
# ../pvNotAssigned.st:15: error: parameter 1 to 'pvMonitor' was not assigned to a pv
# ../pvNotAssigned.st:16: error: parameter 1 to 'pvGet' was not assigned to a pv
# ../pvNotAssigned.st:17: error: parameter 1 to 'pvPut' was not assigned to a pv
# ../pvNotAssigned.st:26: error: parameter 1 to 'pvAssign' was not assigned to a pv
# ../pvNotAssigned.st:27: error: parameter 1 to 'pvMonitor' was not assigned to a pv
# ../pvNotAssigned.st:28: error: parameter 1 to 'pvGet' was not assigned to a pv
# ../pvNotAssigned.st:29: error: parameter 1 to 'pvPut' was not assigned to a pv
# ../pvNotAssigned.st:20: error: parameter 1 to 'pvAssign' was not assigned to a pv
# ../pvNotAssigned.st:21: error: parameter 1 to 'pvMonitor' was not assigned to a pv
# ../pvNotAssigned.st:22: error: parameter 1 to 'pvGet' was not assigned to a pv
# ../pvNotAssigned.st:23: error: parameter 1 to 'pvPut' was not assigned to a pv
# ../pvNotAssigned.st:34: error: parameter 1 to 'pvAssign' was not assigned to a pv
# ../pvNotAssigned.st:35: error: parameter 1 to 'pvMonitor' was not assigned to a pv
# ../pvNotAssigned.st:36: error: parameter 1 to 'pvGet' was not assigned to a pv
# ../pvNotAssigned.st:37: error: parameter 1 to 'pvPut' was not assigned to a pv
# make[3]: *** [pvNotAssigned.c] Error 1
# syncq_not_assigned result=512, response=:4: error: variable 'x' not monitored
# make[3]: *** [syncq_not_assigned.c] Error 1
test.t .. 11/15 # syncq_not_monitored result=512, response=:5: error: variable 'x' not monitored
# make[3]: *** [syncq_not_monitored.c] Error 1
# syncq_size_out_of_range result=512, response=:6: error: queue size '0' out of range
# make[3]: *** [syncq_size_out_of_range.c] Error 1
# varinit result=512, response=../varinit.st:4: error: initializer element is not constant
# ../varinit.st:8: error: initializer element is not constant
# ../varinit.st:8: error: (near initialization for â??UserVar_test.yâ??)
# ../varinit.st:9: error: initializer element is not constant
# ../varinit.st:9: error: (near initialization for â??UserVar_test.yyâ??)
# ../varinit.st:13: error: initializer element is not constant
# ../varinit.st:13: error: (near initialization for â??UserVar_test.UserVar_test.zâ??)
# ../varinit.st:15: error: initializer element is not constant
# ../varinit.st:15: error: (near initialization for â??UserVar_test.UserVar_test.zzâ??)
# make[3]: *** [varinit.o] Error 1
test.t .. 14/15 # varinitOptr result=512, response=../varinitOptr.st: In function â??G_prog_initâ??:
# ../varinitOptr.st:6: error: initializer element is not constant
# ../varinitOptr.st:6: error: (near initialization for â??pVarInit.xxâ??)
# ../varinitOptr.st:10: error: initializer element is not constant
# ../varinitOptr.st:10: error: (near initialization for â??pVarInit.UserVar_test.yâ??)
# ../varinitOptr.st:11: error: initializer element is not constant
# ../varinitOptr.st:11: error: (near initialization for â??pVarInit.UserVar_test.yyâ??)
# ../varinitOptr.st:15: error: initializer element is not constant
# ../varinitOptr.st:15: error: (near initialization for â??pVarInit.UserVar_test.UserVar_test.zâ??)
# ../varinitOptr.st:17: error: initializer element is not constant
# ../varinitOptr.st:17: error: (near initialization for â??pVarInit.UserVar_test.UserVar_test.zzâ??)
# make[3]: *** [varinitOptr.o] Error 1
# Looks like you failed 1 test of 15.
test.t .. Dubious, test returned 1 (wstat 256, 0x100)
Failed 1/15 subtests
Test Summary Report
test.t (Wstat: 256 Tests: 15 Failed: 1)
Failed test: 2
Non-zero exit status: 1
Files=1, Tests=15, 7 wallclock secs ( 0.02 usr 0.01 sys + 5.05 cusr 1.33 csys = 6.41 CPU)
Result: FAIL
Failed 1/1 test programs. 1/15 subtests failed.
- Re: Sequencer news: latest snapshot Benjamin Franksen
- Sequencer news: latest snapshot Benjamin Franksen
- Re: Sequencer news: latest snapshot J. Lewis Muir
Re: Sequencer news: latest snapshot Tim Mooney
<2011>
<2011>
