1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SOAP device communication.
To: Scott Baily <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Mon, 20 Jun 2011 10:58:34 +0200
Scott Baily wrote:
I would like to have an IOC talk to hardware that communicates using SOAP. In theory, I could setup an appropriate protocol file for Streamdevice and use a raw TCP connection to port 80. Has anyone done this? Is there a better method?
Hi Scott,
I would try to do this with StreamDevice. However, StreamDevice requires that the general form of the message is always the same. In particular if you have multiple values in one message, the values should always come in the same order. In SOAP, you could in principle have arbitrary order, and arbitrary numbers of values, too. But normally a device would not change the format randomly.
On the other hand, an XML parser for EPICS may be an interesting exercise.
Dirk
SOAP device communication. Scott Baily
Prev: RE: AreaDetector: Prosilica camera on different subnet? Mark Rivers
Next: Bronkhorst E-7000 series -stream device support? Burkhard Kolb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: SOAP device communication. Peter Milne
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
