On Sat, Jun 18, 2011 at 5:12 AM, J. Lewis Muir <[email protected]> wrote:
> On 6/17/11 3:44 PM, Scott Baily wrote:
>> I would like to have an IOC talk to hardware that communicates
>> using SOAP. In theory, I could setup an appropriate protocol
>> file for Streamdevice and use a raw TCP connection to port 80.
>> Has anyone done this? Is there a better method?
> Hi, Scott.
> If you can get that to work with your particular device, that
> may be the easiest solution. I've done something similar just
> using asyn records to query readings from a temperature and
> humidity sensor via HTTP.
> A better method, but more work, would be to actually use a SOAP
> library on the IOC to communicate with the device. Since SOAP
> uses XML, you would need an XML parser which would typically be
> included with or used by your SOAP library. With your
> StreamDevice approach, you are really just doing pattern
> matching which is likely to work with your particular device,
> but could fail given a different device implementing the same
> API (e.g. XML allows whitespace characters in lots of places and
> one device could place them differently than another).
> While not perfect, in most situations I'd probably do something
> like what you are thinking with StreamDevice (or asyn records).
> Lewis
Hi Scott
Decoding a SOAP document by parsing the characters may be hard work.
I'd echo Lewis and say use an XML parser, actually go one step
further and use a SOAP package like gSOAP to write a client app that
talks to the service. Two advantages to this (apart from portability,
above), it's easy to test and debug a standalone app, and you can then
choose a simple fixed output format that would let you easily parse
the info in EPICS. I mention gSOAP because it's C++, compiles down to
a small binary and we've used it successfully on relatively low power
hardware.
/Peter
- SOAP device communication. Scott Baily
- Re: SOAP device communication. J. Lewis Muir
RE: AreaDetector: Prosilica camera on different subnet? Mark Rivers
<2011>
Re: SOAP device communication. Dirk Zimoch
<2011>
