1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Sequencer Preprocessor Build Rules
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS tech-talk <[email protected]>, Benjamin Franksen <[email protected]>
Date: Fri, 10 Jun 2011 10:14:15 -0500
Hi Lewis,
On 2011-06-09 J. Lewis Muir wrote:
> My vote would be to fix the preprocessor; it shouldn't do that
> substitution.
That means removing $(OP_SYS_CPPFLAGS) from the options passed to the
preprocessor when we run it before the SNC.  However anyone who has an  #ifdef
vxWorks  that modifies their SNL code when building it for vxWorks isn't going
to be very happy with that.
> Why does using "vxWorks.h" work when <vxWorks.h> does not?
> Because it thinks "vxWorks.h" is a C string constant and so
> doesn't touch it?
Correct, the pre-processor does not replace tokens inside quoted strings.
> I'm not the biggest fan of using "vxWorks.h".  It's, as you
> said, a workaround.  When I read that, I think the author wrote
> a vxWorks.h header file and wants to include it.
I just worked out how to fix this nicely: Change the definition in Base's
configure/os/CONFIG.Common.vxWorksCommon to this:
    OP_SYS_CPPFLAGS += -DvxWorks=vxWorks
Works perfectly, and will only break code where someone is using  #if vxWorks
instead of  #ifdef vxWorks.  Just don't try %%#including a file called CPU.h
though, I can't fix that one...
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: Sequencer Preprocessor Build Rules J. Lewis Muir
Sequencer Preprocessor Build Rules Andrew Johnson
Prev: driver support for SIS3302 and SIS3305 Hu, Yong
Next: Re: Sequencer Preprocessor Build Rules J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Sequencer Preprocessor Build Rules J. Lewis Muir
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
