1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Sequencer Preprocessor Build Rules
Cc: EPICS tech-talk <[email protected]>, Benjamin Franksen <[email protected]>
Date: Thu, 09 Jun 2011 17:22:56 -0500
On 6/9/11 11:58 AM, Andrew Johnson wrote:
> Comments/ideas?  Just document it and ignore it?
Hi, Andrew.
My vote would be to fix the preprocessor; it shouldn't do that
substitution.
Why does using "vxWorks.h" work when <vxWorks.h> does not?
Because it thinks "vxWorks.h" is a C string constant and so
doesn't touch it?
I'm not the biggest fan of using "vxWorks.h".  It's, as you
said, a workaround.  When I read that, I think the author wrote
a vxWorks.h header file and wants to include it.
Your suggestion to adjust the sequencer's build rules seems like
an OK workaround if fixing the real problem is considered
undesirable.
I'm not a big fan of deleting the line completely.  That just
makes it harder to understand how it works.  I can no longer
just look at the source code.  I'd have to look at the generated
build command at build time to figure out that vxWorks.h gets
included.
Lewis
Re: Sequencer Preprocessor Build Rules Andrew Johnson
Prev: driver support for SIS3302 and SIS3305 Hu, Yong
Next: Re: asyn connection management with asynPortDriver Euan.Troup
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Sequencer Preprocessor Build Rules Andrew Johnson
Next: Re: Sequencer Preprocessor Build Rules Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
