1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Compiling Problem windows
To: "J. Lewis Muir" <[email protected]>
Cc: [email protected]
Date: Mon, 6 Jun 2011 16:56:29 +0200
Hi Lewis,
I compile with the cygwin environment + VC10. So here the /bin/sh is
available. The perl-script makes the call and in the win32-x86
everything is working. This is what I did not understand.
Best
  Helge
-----Original Message-----
Sent: Montag, 6. Juni 2011 16:45
To: Brands Helge
Subject: Re: Compiling Problem windows
On 6/6/11 2:53 AM, Brands Helge wrote:
> Hi,
> I have some troubles with make on windows-x64 since the revision 12242
> I got :
> /bin/sh: REM: command not found
> make[3]: *** [../../../bin/windows-x64/convertRelease.pl] Error 127
> make[2]: *** [install.windows-x64] Error 2
> make[1]: *** [tools.install] Error 2
> make: *** [src.install] Error 2
> The cygwin-x86 and the win32-x86 on the same machine runs without any
> problem
Hi, Brands.
According to
  <https://code.launchpad.net/~epics-core/epics-base/3.14>,
Andrew Johnson made a change in revision 12242 which may have caused
this new behavior.  This change is likely based on Ben Franksen's email
to Tech-Talk:
  <http://www.aps.anl.gov/epics/tech-talk/2011/msg01002.php>.
However, since I see the following in your output,
I'm confused as to why you're running "/bin/sh" if you are performing a
native windows-x64 build.  I don't have experience building for Windows,
but that doesn't seem right.  I would expect you to be using cmd.exe for
your build.  Can you try switching to cmd.exe?  I think the build system
is expecting to use REM as a comment, which would work in cmd.exe, but
is not a comment in /bin/sh.
Lewis
Compiling Problem windows Brands Helge
Re: Compiling Problem windows J. Lewis Muir
Prev: Re: Compiling Problem windows Andrew Johnson
Next: RE: Dynamic images in BOY Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Compiling Problem windows J. Lewis Muir
Next: Re: Compiling Problem windows Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
