Subject: |
Sequencer news: latest snapshot builds and runs under Windows |
Benjamin Franksen <[email protected]> |
To: |
Date: |
Tue, 31 May 2011 22:34:23 +0200 |
the latest snapshot I uploaded today fixes all the build problems on native
win32 (I used Windows XP running in a VM under Ubuntu and EPICS base
3.14.12.1). I have not yet installed cygwin so this platform may still have
problems.
The tests also build and run w/o errors. However, 'make runtests' sometimes
hangs in the middle of executing the validation tests; restarting it (after a
Ctrl-C) usually helps. I have not found out what exactly causes these hangups,
but I am almost certain that there is something wrong with the perl test
harness, since I never experienced them when running the test scripts manually
(i.e. 'cd test/validate/O.$(T_A); perl xxx.t').
BTW, I had to make *no* functional changes to the sequencer or compiler code
to make the test suite run through. The only things I had to change were
- many details in the build system
- replace all uses of C99 features by proper conservative C90
- add some Windows specific header includes
- adapt the test script builder
All this makes me confident that a release candidate for 2.1.0 is not too far
off.
BTW, I found a small bug in the EPICS build rules that causes errors when
using 'make -s' on (native) Windows: the definition of the ECHO variable uses
"#" (instead of the echo command) if the MAKEFLAGS contain 's', however on
native Windows "#" does not start a comment! Instead you get "error command #
not found". Using "REM" on Windows fixes this. The snapshot contains a patch
that supplies a workaround by overriding ECHO.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Prof. Dr. Dr. h.c. Wolfgang Eberhardt, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: How does EPICS increment its clock for timestamp Andrew Johnson
EPICS on Delta Tau Power PMAC Bill Cruise
<2011>
<2011>
