John,
Sadly, no, I don?t have a simple multithreaded client source code to send
you. The manual does cover this topic, but it doesn?t include an example. I
should write one and include it in the application templates - or in the
manual.
Nevertheless, the ca details are fairly easy. The hardest part of writing
multithreaded client will be protecting your data structures from
asynchronous callbacks.
To write a multithread ca client code one only needs to create a preemptive
callback ca context, spawn a thread, and then attach to the previously
created ca context with the new thread.
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of John Dobbins
> Sent: Wednesday, May 18, 2011 2:08 PM
> To: EPICS Tech-Talk
> Subject: multi-threaded client example
> I would like to create a c++ client which is capable of handling
> monitors as well as doing other things, e.g. write to a PV in response
> to some event. To this end I am looking for example code that covers the
> essential aspects of creating a multi-threaded client. Can someone
> recommend a basic example to look at?
> John Dobbins
> Cornell Laboratory for Accelerator-based Sciences and Education
> Cornell University
Problem installing sscan 2-6-6 on cygwin Zhan Zhang
Re: Problem installing sscan 2-6-6 on cygwin Tim Mooney
<2011>
multi-threaded client example John Dobbins
problem with gateway and softIoc running on same server Kevin Tsubota
<2011>
